Premier Wonder Grinder Repair - Belts and Gears
10,222
4
Posted
Introduction: Premier Wonder Grinder Repair - Belts and Gears
Whether you're using the Premier to grind lentils or cocoa nibs to make chocolate, these machines definitely do wear down and need maintenance, especially if you notice black soot gathering around the base.
Bhavani is the main guy in the US who sells spare parts for these grinders, and it is highly recommend that you contact him rather than trying to find random parts for these grinders. He can be reached at bhavani@dtnj.com
The single most important thing to remember about working on any piece of electric equipment - UNPLUG THE MACHINE BEFORE DOING ANY WORK! I cannot stress this enough. Even with the machine unplugged, there is always still the risk of electric shock. Do not dissemble the grinder any further than these steps - there's really nothing else you can work on.
Step 1: Unscrew the Metal Shaft
Before doing anything else, unplug the Premier and hit the on/off switch to make sure there's no residual charge.
You may have to use quite a bit of force but these do unscrew.
Step 2: Pop Off the Plastic Ring Around the Drive Shaft
You can do this with finger pressure.
Step 3: Pop Out the Rubber Plugs From the Cover
Step 4: Unscrew the Four Screws That Connect the Top Blue Plastic Cover to the Motor
Step 5: Look at Your Gears
There are three things to work on - the large plastic gear, the smaller aluminum gear, and the belt that connects the aluminum gear to the motor.
The plastic gear pops off the base with significant force.
The aluminum gear is bolted to the base and can be unscrewed.
Step 6: Line Everything Up
When you're putting the plastic cover on, make sure the power button is resting on the spring which sits on the red power switch. The back of the cover has a slot for the power cord. This can be a bit tricky to line up.
Step 7: Screw Your Base Back in and Replace the Rubber Covers
Step 8: Document Your Maintenence
Especially when you have more than one grinder (we seem to get a new one every month or so these days), it's important to document which grinder is at which stage. We've noticed the serial numbers gradually going up with each new grinder we buy, so we write the serial number on the side so we can easily see which machine is which, and what maintenance was done.
Now that you've completed these steps, get back to grinding!
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    3 Comments
    Thanks, worked great. I might add I got the parts from e-mailing the address you suggested and he directed me to https://www.melangers.com/collections/spare-parts/products/upgrade-kit
    Thank you
    Thanks for the thorough Instructable! Hopefully we'll see many more from you in the future!
