Premiere Pro Edit Dial Controller (Seek / Play / Pause) ($6 DIY)
3,000
85
13
Posted
Introduction: Premiere Pro Edit Dial Controller (Seek / Play / Pause) ($6 DIY)
I’m really into making Youtube videos for Instructables. Sometimes it is hard to rewind the moment I wanted pause. So, I thought it would be nice if I had a dial for it.
[ Instruction ]
Manual https://sites.google.com/view/100happythings/15-p...
Source Code https://github.com/happythingsmaker/PremiereProDi...
3D Printing File https://www.thingiverse.com/thing:2810760
[ About the maker ]
Youtube Channel http://www.youtube.com/EunchanPark
Step 1: Preparing Materials and Tools
[3d printing]
[ Parts ]
[ Tools ]
Step 2: Assemble the Encoder and the Arduino
The very first step is soldering.
This weird connection shows that I didn’t want to use any wires for soldering it at all.
I used digital output for giving ground and 5v.
It works well!
Step 3: Solder 5 Pins. It Is All!
Solder all 5 pins.
it is very easy.
Step 4: Put the Circuit Board Into the Drum Frame.
There is vertical hole on the side wall.
It is for usb terminal
Step 5: Fasten It
I uploaded a nut shape model on the thingiverse just in case you don’t have a proper size of nuts.
(Using a M7 nut is better way.)
Step 6: Glue It (Optional)
If you want to fix it completely, glue it.
Step 7: Put Coins Into the Bottom Frame
Put 4 quarter into the bottom frame for making it heavy.
Step 8: Assemble Them Together
Step 9: Assemble the Dial Knob
Put the dial into the frame or you can use other knobs for it.
You can use other knobs (I prefer smaller one)
Step 10: Download the Source Code From Github
https://github.com/happythingsmaker/PremiereProDia...
just in case, here is code
#include "Keyboard.h"
#define OUTPUT_B 15 #define OUTPUT_A A0 #define BUTTON A1 #define PIN_5V A2 #define PIN_GND A3
bool aState; bool aLastState; int lastButtonState = 0;
void setup() {
Keyboard.begin();
pinMode(OUTPUT_A, INPUT); pinMode(OUTPUT_B, INPUT); pinMode(BUTTON, INPUT_PULLUP);
pinMode(PIN_5V, OUTPUT); pinMode(PIN_GND, OUTPUT); digitalWrite(PIN_5V, HIGH); digitalWrite(PIN_GND, LOW);
Serial.begin(9600);
aLastState = digitalRead(OUTPUT_A); } bool count = 0; bool keyFlag = false; long lastClickTime = 0; long lastRotateTime = 0;
void loop() {
if (millis() - lastClickTime > 1000) { aState = digitalRead(OUTPUT_A); if (aState != aLastState) { if (digitalRead(OUTPUT_B) != aState) { Keyboard.press(KEY_LEFT_ARROW); } else { Keyboard.press(KEY_RIGHT_ARROW); } Keyboard.releaseAll(); aLastState = aState; }
if (digitalRead(BUTTON) == LOW) { if (lastButtonState == HIGH) { Keyboard.print(" "); lastClickTime = millis(); } lastButtonState = LOW; } else { lastButtonState = HIGH; } }
Step 11: Plug USB Cable
Meanwhile, plug usb cable into your arduino board and your PC.
if you didn’t install the arduino IDE, please install it.
Step 12: Select Leonardo
Select Arduino Leonardo in the Tool bar - Board - Arduino Leonardo
Step 13: Select Com Port
And Select the Communication Port which is in Tool - Port.
You can see the new port when you plug your Arduino to your pc
Step 14: Upload
Now, Hit the upload button
Step 15: Confirm "Done Uploading"
If you can see “Done uploading” text, it means done.
Step 16: Congratulations! DONE!
It has a click switch.
Everytime you click it, the arduino sends a space text.
So, you can make the premiere pro play and pause.
I think you guys have been suffered from this situation.
For example, I wanted to pause when the scene is changed.
But I cannot stop it immediately, So, I had no choice but to seek it by clicking here and there.
Now with this dial, I am able to seek it way better than ever.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    11 Comments
    Can this also work with Vegas Pro 14 or newer versions? Thnks!
    Hi again, I made and uploaded the source code for Vegas. It will be working well. when I rotate it counter clock wise, it press Alt+Left arrow. when counter wise, Alt+right arrow. :)
    Thank you a lot!! You are the best!!!
    Also one more question, can i use arduino nano instead of leonardo?
    You are welcome, unfortunately, nano is not support it as far as I know. even though it is possible, it could be more complex and difficult than using arduino micro.
    Hi!
    it is kind of keyboard. so I put left arrow button and right arrow button function to this project. As I found the shortcut of Vegas, it is ALT + LEFT_ARROW, ALT+RIGHT_ARROW. (is it right? I found it here : https://shortcutworld.com/Vegas-Pro/win/Vegas-Pro_... )
    Let me make a code for Vegas. I will put an additional comment here when I finish it.
    Awesome idea, gonna have to make a couple of these
    Thanks for your comment! I hope this instruction helps.
    If you have any question, please let me know, I will do my best for it :)
    Just wanted to add, if you feel the need to have music throughout the entire video, even while you are talking, please please please, do not have the music playing as loud as your speaking. The music throughout the entire is just unnecessary and distracting from an otherwise quality instructable.
    Hi StanleyM45, Thanks for letting me know about the loud music.
    Yes, I will turn the music volume down or will not use music at all. Thank you very much for your comment!
    Looks like it would make video editing even more fun too!
