If you don't know what a PIR sensor is, just have a look at Wikipedia http://en.wikipedia.org/wiki/Passive_infrared_sensor . The product where the boards comes from can be bought here http://www.greasemonkeyconversions.com/10609/Com_N_Sense_Hands-Free_Kit_(Nokia_3310_etc).shtml . I bought the boards from a seller named "kalleb" on eBay. A search of the seller or for the subject "PIR INFRARED SENSOR" leads to the offer. He still offers some boards.
On the boards you can also find some switching voltage converters. I used them in an other project http://www.instructables.com/id/SLVOL8FFBGW8AF4/ where I needed to get +-15V out of a +5V supply. There are other useful components as well, but here we only need the pir sensor and the op amp that prepare the pir signal for direct usage with a microprocessor.
Remove these ads by
Signing UpStep 1What you need
for preparation:
- a soldering iron
- tin-solder
- a jigsaw
for testing:
- a tabletop power supply with a +5V output (0.2A current is enough for testing)
- a voltage meter
- some wires
If you try optical lenses, make sure that they're transparent in the mid-IR that these sensors see. Glass isn't. Plastic lenses from a disposable camera might be, but I haven't checked. The polyethylene used to make the Fresnel lenses is, of course.
I'm considering buying a bunch of bare PIR sensors from Goldmine Electronics (www.goldmine-elec-products.com/prodinfo.asp?number=G9270). Assuming the part is what they say it is, it comes with a transistor preamp. Building an array of these, with some tiny op amps might make a nice lo-res camera!
You can use the schematic I send here to build a working sensor, but you have to build it on your own.
Before I bought this small boards I experimented with sensors. The signal that comes straight out of them is very small, only some mV.
Have a look here to find out how the electronics work.
http://optoelectronics.perkinelmer.com/content/ApplicationNotes/APP_PyroElectronics.pdf
