3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make Your Own Prescription Swimming Goggles
Step 5Sanding the Surfaces in Preperation for Gluing
The edges of the prescription glass lenses that overlap the goggle frames need to be sanded for better glue adhesion, if you are using plastic lenses.
Using the fine grit sandpaper, lightly sand around the edge of the lenses (on the inside surface) where they will be glued to the goggles.
You should also lightly sand/roughen the goggle frames to which the sanded edges of the lenses will touch. This will help the glue adhere to the goggles.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:engineerable
Daniel Bauen breathes new life into objects that have met their untimely demise in the junk pile.
