I used a one gallon garden sprayer (Spectracide #27019 at Lowes (about $13USD)), added a chuck to use a compressor to pressurize it (optional (note do NOT use over 20PSI)). A 90 degree 1/4 turn water valve ($4USD) with a 3/8" compression fitting on one side and a 3/8" hose fitting on the other side. Removed the sprayer valve, and replaced it with the water valve, added the tire valve and it works great (and it was much easier than I thought it would be).
Throughput is about 1 liter / minute.
I have not found a commercial tool that does this for civilian use. I put a 2" piece of 3/8" clear tubing ($0.25/ft) over the hose fitting side of the valve just for a little extra reach (I needed a 6" piece for the front diff) adjust to your own needs. And a hose clamp on the hose end for security ($0.50USD).
Remove these ads by
Signing UpStep 1Add the tire valve
Make sure the edge of the gasket will fit up through the hole for a good seal.
You might need a rat tail file to clean up the hole.
These are the 0.45" (to 0.625) valves at Napa and Advanced Auto Parts.
I guess you could use a 1/2" drill bit, but I liked the tight fit of the 29/64" bit.
Greg
