Step 2Remove hand sprayer valve
The compression fitting worked great on this particular sprayer Spectracide #27019 brand 1 gal sprayer.
I added a small hose clamp because of the pressure (note do not use more than 20lbs).
The build in pump should work also, but I did not test that as it was not the design, and might take a while.
The dip tube has a filter screen on it, I left it there (can not hurt), but it does not allow total fluid extraction.
You could cut the filter off and the tip will rest in one of the reservoirs that make up the 'feet' of the bottle.
You will need to note (and can reach in with a screwdriver and adjust) where the pickup is, so you can tilt the bottle that way to maximize fluid exaction.
Add Comment
