Introduction: Pressurized Spray Bottle From Old 2-liter
I am going to show you how to make a pressurized spray bottle from an old 2-liter pop bottle. I had a store bought sprayer but it required that I actually pump. Since I am very lazy I made this so my air compressor could do all the work.
Step 1: Materials
I made this out of some leftover plumbing odds and ends I had. This is my first instructable so feel free the let me know where I can improve.
Materials :
PVC
1 1/2" Tee
1 1" adapter
1 1" x 1/2" Bushing
2 1/2" plugs
1 piece of 1/2" pvc pipe about 1" long
Brass
1 1/4" hex nipple
1 1/4" x 2" nipple
3 1/4" x 1/4" barbs
1 1/4" valve stem
Other
1 rubber tip blowgun
1 1/4" quick connect stud
purple primer
pvc cement
teflon tape
5' of Polyethylene Tubing 3/8" o.d. x 1/4" i.d. 165 psi
Tools
1/2" drill bit
Drill
ajustable wrench
Materials :
PVC
1 1/2" Tee
1 1" adapter
1 1" x 1/2" Bushing
2 1/2" plugs
Brass
1 1/4" hex nipple
1 1/4" x 2" nipple
3 1/4" x 1/4" barbs
1 1/4" valve stem
Other
purple primer
pvc cement
teflon tape
Tools
1/2" drill bit
Drill
ajustable wrench
Step 2: Pressure Test Adapter
First off I am going to modify the lid so that I can do a pressure check on the 2 liter that I am going to use.
- drill a 1/2" hole in the bottle lid
- Wrap teflon tape around the threads of the quick connect stud
- Thread stud into the lid
Step 3: Assembling the PVC Fittings
Now we are going to put together most of the pvc pieces. I widened the hole in the lid just to give myself a little more room to work but it is not nessesary. Remember to use purple primer and PVC cement on every step.
- glue the lid inside the adapter
- glue the bushing to the adapter
- glue the piece of PVC pipe into the bushing
- glue the tee fitting verticaly onto the pipe
Step 4: Brass Fittings
Now we are going to assemble the brass fittings. When you are drilling the hole in the plugs you will probably have to work your way up to the 1/2 inch bit to keep it from getting bound up. Use teflon tape on all brass fittings.
- Drill a 1/2" hole in both the PVC plugs
- Thread the strater valve into one of the plugs
- Attach barb to 2" nipple
- Thead 2" nipple/barb into the remaining PVC plug
- Attach barb to the other end of the 2" nipple
- Attach the hex nipple to the blow gun
- Attach the last barb to the hex nipple
Step 5: Finish the Sprayer
Now we can put everything together. Use purple primer and PVC cement on both of the plugs.
I keep the pressure on mine at around 60 psi. I tried going up to 80 but the bottle lid came free of the adapter so I had to turn it down a bit.
- Glue the valve stem/plug onto the tee fitting at the horizontal branch
- Cut a piece of tubing approximately 13" long and attach it to the barb on the inside of the plug
- glue the barb/plug to the top of the tee fitting with the tube going inside the tee
- Attach the remaining tubing to the last two barbs to connect the bottle to the blow gun
