Preventive Maintenance for Spy Cameras, Etc.
11,202
20
14
Posted in TechnologyGadgets
Introduction: Preventive Maintenance for Spy Cameras, Etc.
About: I have no interest in friends, women or men. Although friends are nice to have, I really could not care less what anyone thinks of me and I can get on perfectly well without friends. Getting drunk, wasted or...
Some people who own spy pens and various other mini cameras and devices complain about buttons snapping off inside and the device just ending up as the technological equivalent of a vegetable. You can make your device last much longer with some araldite and some patience. This instructable features the MD80 video camera. I think it is a fake version of it.
You will need:
Araldite rapid or precision extra strong Good quality epoxy will also work.
A smooth plastic card to mix the Araldite
A knife with a magnetized sharp point so that you can remove tiny screws from your device
A small plastic stick to mix the Araldite
The thing that you want to fix
A heater. This is optional and will be explained further on.
Step 1: Disassemble Your Device
Very carefully, remove the screws and put them in a safe place. Use a bottle lid to store them. Try not to scratch the casing of your camera because you want it to look on the outside as if it has never been touched. Once all the screws are out, very carefully try to part the casings on the device. Watch out for the wires that go to the microphone and the battery. If these come off, you will struggle to fix them. Completely remove the circuit board and battery from your device and place them aside.
Step 2: Mix the Araldite and Apply to the Board
Mix the Araldite thoroughly for a minimum of 45 seconds, then apply it with extreme care to the back and sides of the buttons. If you want, you can also spread it all over the board. This will greatly improve the moisture resistance of the camera. You should also apply it to the battery and microphone wires so that they do not come off. In particular, cover the two clock crystals with Araldite. These are the first things that cause problems when things get wet. If the wires to the clock crystals get soaked enough, they stop working until the device is dry again. The clock crystals look like small metal cylinders with wires on the bottom. They are on the other side of this board in the picture.
Step 3: Heat the Araldite (optional) But Really Speeds Things Up
If you chose to completely cover the board in Araldite, you will notice that it is hard to get into all the little spaces between the components. If you use a red hot heating element and move it closer to the Araldite until it starts to flow into all the little gaps you can get the board covered more effectively. This also greatly speeds up the hardening time. Do not heat it too much as it will burn. Araldite rapid will start to smoke at a lower temperature than the extra strong. Also watch that the glue does not get into the front of the buttons. If it does, then you will have ruined your camera. It is best to keep the glue to the back of the buttons.
Step 4: Have Some Noodles or Do Something Else for 2 Hours.
The heated Araldite will take 2 hours to become rigid enough to allow you to turn the device over and cover the other side.  If you chose not to heat it, you will have to wait about 5 hours.
Step 5: Coat the Other Side With Araldite
The other side of this camera was a bit more tricky as I had to bring the USB port and card slot into consideration. I did not put very much Araldite near these areas at all. Since the processor and the two crystals are very important, I have completely encapsulated them in Araldite so that they will resist moisture much more effectively. Use the Araldite sparingly around the USB ports and the card slot.
Step 6: Leave the Whole Thing for at Least 24 Hours
If you used Araldite rapid, you could leave it for 12 hours before putting it back together. Put it in a place where it will not be interfered with in any way. You could place it on top of a radiator to speed up the hardening.
Step 7: Put It All Back Together and Test
Now you should end up with a camera that will last longer and resist moisture better.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    14 Comments
    The spy cams make sure that all the activity
    going on gets recorded in your absence.
    http://www.spymumbai.com/spy-camera-in-pune.html
    Action India Spy cams are highly
    useful in all situations whether its protecting your loved ones or making sure
    that you don’t suffer any loss at business.
    http://www.spybangalore.com
    http://www.spybangalore.com/spy-camera.html
    Spy cams are widely used to keep an eye on your
    house helps and employees while you are away. The spy cams make sure that all
    the activity going on gets recorded in your absence.
    It also sticks Ford Cortinas to walls.
    Mr. Lopez I have no idea as to why you posted this Link would you please elaborate. Thanks...Thom
    Well, Thom,  I will try my best to explain this.
    My comment was merely to help illustrate what Sdobbie was saying about the clear, goopy adhesive used in this instructable, called "Araldite(r)" in his country, but called "epoxy" in my country, being used to stick cars to billboards.
    Specifically Sdobbie said, "It [Araldite(r)] also sticks Ford Cortinas to walls."
    When I first read that statement, it did not make any sense to me at all, but slowly I figured out that this was a popular meme in Sdobbie's home country, no doubt unleashed on the public those scoundrels in the advertising/marketing industry, and you can learn all you need to know about the marketing-mongers by watching this:
    http://www.youtube.com/watch?v=gDW_Hj2K0wo
    So I figured I'd post a link, because this would be helpful to anyone reading this unfamiliar with the that meme.
    Now anyone reading this thread who is unfamiliar with "Araldite" or "Ford Cortinas",  just look at the picture and say, "Ah! I get it now!  That Araldite (aka epoxy) must be some pretty strong glue, if it can hold an car to the sheer side of a billboard!"
    Although I'm not at all convinced that epoxy can truly glue a car to a billboard like that.  To me that stunt/billboard looks fake, fake like a three dollar bill, but you know, that's marketing...
    But that's not the point.   The point is that the stuff Sdobbie kept referring to as "Araldite", in this instructable, the stuff that I was wondering what that glue was, was actually epoxy, what people in my country call "epoxy".
    If you are looking for some sort of deeper wisdom here,  the lesson is that people in different parts of the world use different names to refer to objects that are essentially the same.  A classic example of such an object known everywhere, but by different names, is the Royale with Cheese:
    http://en.wikipedia.org/wiki/Royale_with_Cheese#Product_description
    I suspect troll, but cool story bro.
    Thanks your the man alright really great response enjoyed it much...Thom
    Thanks very nice, I have a few of the MD80s use them like there made for and your all good, ....Thom
    You can not fix buttons with one of those.
    Yup. You nailed it!
