3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Princess Peach Pointillism
1080 980 plastic bottle caps + 16 acrylic paint colors + a couple of Perl scripts + 6 months worth of work =
Step 1Materials
Materials
First, convince your entire family to start collecting plastic bottle caps. To make things even more fun, don't tell them why they are collecting caps.
Select a suitable picture, in my case I selected a 30 x 36 image of Princess Peach. Be sure to select a small image as you're going to need one cap for every pixel.
Once you have collected at least 1080 caps, you're ready to start phase two.
(Note: It's been pointed out that the image is actually 28 x 35 totalling 980 caps. I forgot that I lost a row and and two columns when I  planned out the border. Small oversight on my part, can't believe someone actually counted!)
53 comments
1-40 of 53next »
Dec 21, 2010. 4:59 PMbelsey says:
Congratulations on being featured in the magazine Nintendo Power!
Dec 22, 2010. 5:23 PMbelsey says:
You most definitely are, amongst the 10 year old boy set!
Sep 9, 2011. 10:15 PMtjesse says:
How could i do this with beer caps? Using the original paint on the cap?
Feb 17, 2011. 5:02 PMsonofspikerr says:
Saw this in Nintendo Power!!! Awesome!!!!!!
Oct 4, 2010. 5:29 PMSlicerr2 says:
does any one know where i can just paste my image in and get a layout like in step 4
Feb 3, 2011. 9:00 PMYolksterXD says:
This is how i did it with Gimp (and im a total noob too so it took me a while to figure it out):
Paste image into Gimp
Image -> Mode -> Indenxed (dont change the options) -> ok
Windows-> Dockable Dialogues -> Colormap
Windows -> Docable Dialogues-> Histogram
The number of the color on Colormap (ex: color index "x") is equal to "x,x" on the Histogram left and right boxes
Dec 11, 2010. 7:49 AMKry says:
awesome
Sep 12, 2010. 9:48 PMMr. TiKi says:
How good did the paint hold? Acrylic to plastic in my experience holds very poorly.
Sep 20, 2010. 10:05 PMBarginsTech says:
Couldnt you use a simple glue spray like elmers spary adhesive and let it dry? Or modge podge with a brush?
Sep 21, 2010. 10:11 PMMr. TiKi says:
Just goto walmart and get yourself some Krylon crystal clear. They have satin, gloss semi, gloss
Sep 21, 2010. 5:06 PMBarginsTech says:
Yes :D
http://www.google.com/products?hl=&rlz=1B3MOZA_enUS359US359&q=modge+podge&um=1&ie=UTF-8&ei=lkeZTJTOGcH38Ab56IGBAQ&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CDwQrQQwAg
Its a puzzle saver glue. I noticed Elmers has a "spray adhesive" that might have the same effect. The only problem I can see with the modge podge is it doesnt have a spray form.
Sep 21, 2010. 6:37 PMMr. TiKi says:
Mod podge won't stick to plastic. And if you want to spray mod podge you could dilute it and use an air gun. I do that on my acrylic 3d wall art to seal in the paint.
Sep 21, 2010. 8:37 PMBarginsTech says:
maybe Shelac? Just thought of it.  My grandma used it for pumpkins and gourds for holidays. I think any thing thats spray would be okay cause its a thin layer and as long as its not haldled so much it shouldnt chip right? I dont have a spray gun so your idea, though it sounds like its efficient, wouldnt work for me :(
Sep 21, 2010. 8:32 PMBarginsTech says:
ahh good point! didnt thik of that... hmm...
Sep 13, 2010. 7:47 AMMr. TiKi says:
You could try minwax polycrylic. Also you could also try some enamel $1.49 at micheals for a 2oz bottle, problem is they take a few weeks to completely dry.
Sep 16, 2010. 10:11 AMPrometheus says:
Just brush acetone over the surface. The "burn" should roughen the surface enough for most paints to stick. "Model paint" with nail-polish as a primer could work too...
Sep 17, 2010. 11:04 PMMr. TiKi says:
Thanks for the suggestion, I will give it a shot.
Sep 17, 2010. 11:47 PMPrometheus says:
I should add that if you use nail polish and model paint, to keep it indoors as excessive sunlight (UV) and weather can deteriorate the nail polish quickly. Some plastics are resistant to acetone. If you brush acetone over it and it does not destroy the glossiness, you may need to just use plain coarse sandpaper, something around those cheap orange fingernail-file grit (emery board)...The idea is to remove any glossiness. The more reflective it is, the less it's surface area, and we want to maximize that so paint can get a better hold.
Or :rofl: just use those cheap orange emery board nail files where commercial "teen" cosmetics are sold, with names like "revlon", "maybelline", etc., as well as nail gloss/enamel (same animal, I suggest the clear gloss or the "super-vampire-gothic pitchblack midnight death black"/"heaveanly-angel pure-virgin innocence-white", depending on the topcoat color). "Methylated" or acetone-base is suggested, so try to read the "ingredients" if the packaging will let you do so without buying it first (corporate america disgusts me)...
Roughening the surface increases surface area, giving the "paint" more to grab on to. First rule of painting: "several thin coats are more durable than one thick coat." This especially applies to aerosol paints, should you choose to use them. I had found that rust-inhibiting paint sticks just a little better to plastics than standard aerosol spraypaint. Experiment if you can afford to do so...
Sep 19, 2010. 2:11 AMfvu says:
Very nice. If you can collect twice as much bottle caps (2000), you might consider creating bottle cap curtains as well, see: http://fvue.nl/wiki/Fly_curtains_made_of_plastic_bottle_caps . There's no painting involved!
Sep 18, 2010. 7:13 PMsmheck says:
I just showed this to the kids and they LOVED it! You are so VERY creative!!!
Sep 17, 2010. 3:00 PMbgepp1 says:
i'll bet it looks really cool the farther away you get - nice job at recycling materials too!
Sep 17, 2010. 5:32 AMpokster says:
awesome!
Sep 17, 2010. 2:40 AMWingDings says:
Wow - 6 months of work! Well done for keeping going all of that time! :)
It's amazing how quickly the number of points add up as you increase the dimensions. The end result's great.
Sep 9, 2010. 12:33 PMCabanaman says:
Could this be done with spray paint? Patience isn't my virtue, unfortunately.
Sep 16, 2010. 11:13 PMRazzor says:
I had recently done this but with ceramic tiles and a "Space invader" theme, it turned out quite well but was very costly. I love your idea for using bottlecaps and i think i might have to try this myself.
Great instructable :)
Sep 16, 2010. 9:07 AMtim13211 says:
Wow, this is very cool! Do the bottle caps have to be the same size/shape, or does it matter?
Sep 16, 2010. 7:53 PMtim13211 says:
Ok, thanks!
Sep 8, 2010. 8:25 PMcowscankill says:
Awesome! But why peach (of all video game characters)?
Sep 16, 2010. 10:08 AMPrometheus says:
^^comment WIN
Sep 16, 2010. 8:00 AMdermbrian says:
Great answer.
1-40 of 53next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:skeplin(Sanity With Five Kids)
Programmer, mad scientist, tinkerer, father of five!
