loading
I was planning an idea I have for cosplay, and it required princess seams.
Princess seams are usually done on a mannequin, but I don't have one.
Therefore, I figured out how to make a pattern for princess seams out of a t-shirt for myself :D
Step 1: Supplies
- a t-shirt you are willing to cut up
- scissors
- a lot of pins!
- a pen
Step 2: Pinning
Put your t-shirt on inside out
Pin where you want the seams to go-- be careful not to pin yourself!
Step 3: Marking
mark lines about 1/4 inch from the pins, creating a line where you will cut.
they 1/4 inch room you leave is for seam allowance.
unpin the shirt and take it off.
Step 4: Cutting
Cut the shirt along the lines you drew!
also, cut along the side shoulder, and arm seams of the shirt.
*note: to make the right and left sides equal, i cut out the right side and flipped it over to create the left side.
Your pieces should look something like this.
Step 5: Finished
Keep the back piece!
Lay the pieces out and label them.
Just to check that the pieces are aligned correctly, you can repin the pieces.
I am going to use this pattern for a cosplay I am working on, I may post it in the future! :3
About This Instructable
20,533views
48favorites
License:
More by julialam:Watercolor Travel Kit Simple Hat Mod Princess Seam Pattern (without a dress form)
Add instructable to:
