Pringles Lifter
1,118
17
5
Posted
Introduction: Pringles Lifter
pringles lifter
3D printed appliance to pringles chips from the box to pick up anyone
know if your hand is too thick you can not look good at so with this device you can easily hop on pringles from the box lifts
what you need :
for the large one and thats the best
you need a large printer
materials is flexpla (i dit not use others to test it)
dimensions are 27 cm long and 1.5 cm wide
the smal one that u can print on every 3d printer is 20 com long and 1.5 cm wide
Step 1:
print the file
this one is for the big one and best to use
Step 2:
if u wand to print your self
this is the small one
its a bit wider 2mm
you can print on a regular printer
whit exotics
Step 3:
if the are printed the look like this
Step 4:
open the can
put the cap on and lay the pringles box down
so the pringles lay on the underside of the box like pic 3
Step 5:
put the pringles lifter in like ont pic whole the way to the botom
this is importend that the lage back of the lifter whole the way down is
if it not work from the first time try more
Step 6:
turn the lifter 90 degries so it look like the pic
Step 7:
when its all done turn the can so it looks like the pic
Step 8:
now your are ready to pull
you can lay down the can and pull
or pull the lifter up so the pringles are a few cm above the edge of the can and pull back the turn out in the lifter
and let it rust on the edge like pic 1
you can do this
you can pull the pringles up for every 3cm or so
Step 9:
when finis just let the pringles down and bend the lifter in the box and close for next time
Step 10:
the smaller one is a little bit chorter
and more dificult to lift the pringles out the larger box
so i prefer the larger one
does it work yes for 99%
sometimes it's not from the first time to reatch the botom of the can but it works
i hope that you enjoy the pringles lifter
  • I made it but i didn...-raditooo
    raditooo made it!
  • Gluten Free Challenge
  • Epilog Challenge 9
    Epilog Challenge 9
2 Comments
thanks pleas chear
