3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pringles Wind Turbine (Pleech) - Version One
Step 11Make a Base for the Coils
I made my prototype out of foam core, but this will depend a lot on the size of your coils, the size of your magnets and the shape of the frame. Plus, if you're planning on keeping this outside instead of hooked up to an AC vent of whatever, keep weather proofing in mind (and while you're at it, give the Pringles can a good going over with Scotch Gard--I haven't tried it, but let me know what works for outdoor versions you make).
The most important thing is to try to get the coils to be as close to the magnets without collisions. If you can position the coils on the base so they sit just 1 mm below the spinning magnets (watch out for wobble) then you're in good shape. Also, try to make the base as stable as possible. At higher RPMs, the turbine can really start to rattle a bit, so keeping things together in those conditions is crucial.
4 comments
Jun 16, 2009. 8:52 AMkmahalanabis says:
PL NOTE IT HAS TO BE "CLEAR CD"
May 18, 2010. 1:44 AMKintaro Oe says:
The "CLEAR CD"   comes in bulk from 50 or 100 CD / DVD as protection. It is not made.
Mar 29, 2009. 8:31 PMclint114 says:
Could you put a clear CD between them to keep the magnets from bumping onto the coils?
Jun 16, 2009. 8:51 AMkmahalanabis says:
U CAN,WITH A LITTLE CHANGE IN PERMEABILITY......CANT SAY HOW MUCH IT WILL AFFECT CURRENT GENERATION.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:mikejedw
I am an MFA student in Parsons Design and Technology department. I specialize in physical computing, games, mobile applications, and weird little toys.
