That's it! You have a crazy renewable energy source of perhaps dubious usefulness. BUT there is a lot more that can be done. I'd like to throw out a few suggestions to the crowd for thing to try:
- double up the magnets and coils. Put one set on the bottom and one on the top. Wire the DC output of each in serial and double the voltage. Hopefully.
- bigger, badder coils. Really see if you can up those wraps to a crazy degree. I think that's the key.
- take a look at the mintyboost USB charger (http://www.instructables.com/id/EGBQJPLCB2EP287KTZ/). I've spoken with the inventor herself, and she says that the circuit that drives it can work with input voltages between 1.5 and 4.5 volts, with the most efficiency in the middle of that range. It produces steady 5V power off of two AA batteries (which are only 2.4 to 3.0 volts). If you have this project with that one, do you get a wind-powered iPod charger? Try it and let me know.
- try a different bearing. My big thing is to use as simple and readily available parts as I possibly could, so I swore off fancier parts. You have no such limitation. I have it on good authority that skateboard bearings would be great for this. Or some other kind of bushing. Let me know what you come up with (especially if it's hacky, cheap, and better than what I've done.)
- Small lazy susans are available at art and sculpture supply stores that might also make good bearings.
- Made a bunch of these turbines? What happens when you wire them together in series? Can you make a "Pleech" farm?
- There's another more efficient Vertical Axis Wind Turbine design called the Darrieus Turbine (http://en.wikipedia.org/wiki/Darrieus_wind_turbine). It uses lift instead of drag. If you have an easy way to modify this turbine into one of those, drop a comment down here.
What I'd really love is for this to be the first (well, second) version in a long series of continually improving small turbines, the goal of which would be to power small devices (phones, sensors, art projects installed on public buildings, etc.) So, what did I do wrong? And what could be done a whole lot better? If you have answers, let us know. Hopefully, we can "crowd source" a way to make a pretty decent, and fairly cheap, wind powered generator.
and i would upload the images of my project as soon as possible so that u r able understand the problems i am facing.
thank you.
1- how many rounds of coil winding are used in this project.
2- i am not able to understand, on which part of the project is the CD with magnets attached is supported i.e. the CD with magnets is too heavy and needs a very good support. would appreciate if u upload pics of the supporting parts.
3- i would be very happy if u could provide me the link for the video of the making of this project.
4- i wasnt able to find the paper towel holder, therefore i made a wooden holder just like the paper holder.
5- a question- can we use LEDs to show the energy produced, and use a rechargeble battery for storing purpose.
http://www.sciplus.com/recommend.cfm/recommendid/9940
and glue the magnets to the bottom and top of the cage. Gain electricity from both ends. Also there might be no need for a towel dispenser so airflow might be increased.
Levitation bearing magnets could likely be used and thinner coils with more wraps. I was throwing figures in an inductance calculator this Winter and found that the length of the coil really didn't make a difference most of the time except to use more wire, and make the coil more stable. If the coil is glued on a flat surface then stability is not a factor to worry about.
Also, other experiments I have seen use 4 magnets / 3 coils, but the wiring was a little different. That is what makes it tough for me as you guys all have new ideas and do this=ngs a little different. I guess when I finally get around to throwing one together mine while be different again.
Nice job!
Display the following in courier typefont for best results:
Think of the magnetic circuit as an electrical circuit. You want to maximize the flux through the bobbin coils.
We have the magnets as the equivalent of a voltage source starting out of the North pole. The voltage creates flux, the magnetic equivalent of current. the flux exits the north pole of the first magnet,passes through highly resistive (high reluctance in magnetics) air gap (nothing we can do about that but lower the air gap). Then the flux passes through the bobbins. If we wind the bobbins around iron, we get a lower reluctance than aluminum or, say, wood. Then the flux has to go through the base material. If it is iron, it has a lower reluctance. Then the flux passes through the other bobbin, then through the air gap again, then through the other magnet, then through the magnet backing material. All of these materials have a reluctance associated with them. The lower the total reluctance of the magnetic circuit, the more flux passes through the stator coils. Therefore, your motor or generator will work best with low reluctance backing materials. It is more complex than just this, but it amounts to the basics of completing the magnetic circuit.
