3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pringles Wind Turbine (Pleech) - Version One
Step 4Cut, Sand, and Fit the Cork Into the CDs
The wine cork forms the very simple axle of the turbine. I prefer this over the dowel from my first version because:
a) you can make them as snug as you need to
b) you don't hurt the turbine's efficiency by running a dowel through the middle of it (which, according to some of my research, knocks it down by something like eight percent)
You can take an ordinary wine cork and cut it in half, then work the pieces over with a saw and some sandpaper until they fit just right into the CDs' holes.
Be sure not to over cut. Cutting away the outside of the cork is a great way to save time from sanding, but don't over do it. Better too snug than too loose. When you get close to the right diameter for the cork pieces to fit into the holes of the CDs, test and sand and test again.
Once the corks are the right size, pierce them with small nails. These will form a "needle bearing" on which the entire contraption will spin. Try as hard as you can to get the nails to be perpendicular to the CD and as close as possible to the dead center or it. Otherwise, you'll get wobble.
2 comments
Mar 29, 2008. 6:21 AMtechnico says:
instead of cork, use the plastic bottle cap from a 2L soda bottle. Use a push pin through the center of the inside of the cap, super glue in place super glue cap to the cd over the center hole. you can drill small jack holes on the cap to stabilize
Feb 7, 2008. 5:06 PMIronLight says:
One possibility for the needle bearings (I haven't tried the project yet so I can't be sure) might be to smash the plastic off of push pins and use the metal pin inside (close to 3/4 inch long). The fine point might reduce friction significantly if the object of choice has thusfar been at all jagged.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:mikejedw
I am an MFA student in Parsons Design and Technology department. I specialize in physical computing, games, mobile applications, and weird little toys.
