What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
The best thing you can do here is to look at the diagram in the PDF from a few steps back. Basically, you need to attach the magnets (glue, tape, epoxy, whatever works) to the CDs in such a way that the poles alternate. A magnet that faces north follows one facing south follow one facing north, etc. If you're confused, do check the diagram. Marking the poles with a Sharpie also really helps.
hey, I'm making a generator for a project, and I'm making a small scale model, and I was wondering if there was an equation that I could use to calculate the voltage/amp output of it at different rpms, and with different numbers of magnets.
I just bought some magnets, they are listed as N42 Neodymium and are 12mm x 3mmA which I thought would be enough. They have a 2.3 Kg pull force, is this ok for a project like this?
What size are the magnets? Do you think the "20mm dia x 10mmA Neodymium Magnet" N42 grade magnets from http://www.emagnetsuk.com/index.asp?function=DISPLAYCAT&catid=9 would work? Also, do you know approx how many turns would be needed for 36 gauge wire in the coils? I am unsure how much i will need. Thanks, I am using your design for a physics experiment.
That's about the grade of magnet that I used, thought maybe slightly larger in size. As for the windings, the best I can say is that there's a lot. As it happens, I probably would have been better off counting them more exactly, since that would help balance the voltage generated and make it more efficient. Just a question, then, for everyone... how many wraps did you guys find was necessary?
Thanks for your reply, I will go with the larger "25mm dia x 10mmA Neodymium Magnet" with N42 grade, to get a bit of extra voltage. I have to write a 4000 word essay in a subject for school and i'm choosing physics, so i am going to test how the number of turns in the coils affect minimum start up speed, voltage, and current. I will let you know the results when i'm done.
what kind, or grade of magnets are those? i wouldnt imagne them to be too powerful since they are so close but i want to get a estimate of thier "Electricity moving power"... sounds dorky i know =D and how close to the coils are they?
They are actually fairly powerful for their size. I can't recall the exact type now, but I remember them being roughly equivalent in strength to some N40 grade magnets I ordered from amazingmagnets.com. I positioned the magnets so that they'd be as close to the coils as possible without colliding--I think I got within about 2 or 3 mm. Closer is definitely better, if you can manage it.
You can pretty much use anything. CDs worked out to be the right size. We've had discussions on this forum about maybe using steel paint-can lids, too, which might help sort of "amplify" the effect of the magnets. Worth trying!
I am an MFA student in Parsons Design and Technology department. I specialize in physical computing, games, mobile applications, and weird little toys.
