3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pringles Wind Turbine (Pleech) - Version One
Step 7Tap in Dimples into the Paper-Towel Holder
This is the other half of the "needle bearing" I wrote about. You'd need to make this deep enough so that the turbine stays in place but not so deep or so narrow that friction becomes a real problem. Some suggestions:
- with a hammer, tap each end with a small blunt nail followed by a phillips head screwdriver
- don't make a hole, just a deep dent
- test the mechanical action with your turbine frequently
- add WD40
- adjust the height of the nails if there's not enough or too much pressure on the turbine (i.e. it keeps falling out or it's stuck and really slow)
Once satisfied, glue down the corks to the CD
1 comment
Jul 10, 2011. 12:19 PMnerdyH says:
A solvent like wd-40 might be good for flushing away metal dust (say, from aluminum nails). But, I wonder if needle bearings like a little bit of grease, the way so many other types of bearings do?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:mikejedw
I am an MFA student in Parsons Design and Technology department. I specialize in physical computing, games, mobile applications, and weird little toys.
