3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pringles Wind Turbine (Pleech) - Version One
Step 8Wind the Coils
Wind the Coils
This part is crucial. The amount of power you generate pretty much depends on two things: the speed of the wind, and number of coils. Other factors play in, but these are the big ones. You have not control over the wind, though, so make this step count. I highly recommend using thinner gauge wire than I did. I used 28, and got decent results, but I think 36 gauge will blow the doors off of my current set up. It's all about the number of wraps. The 36 gauge stuff is harder to find, so you can make do with thicker stuff--just be aware of the cost of doing so.
Here's how to go about it.
- use a dowel for the big spool of wire
- put bobbin on an awl, then insert the awl into variable speed drill
- leave 10 - 15 cm hanging when you start. You'll need these to make connections later.
- wind the first wrap slowly or by hand. If you're using thin stuff, do it by hand.
- you can increase speed thereafter. Again, be gentle if you have the thin wire.
- go back and forth, try not to cross, be neat.
- if using thin wire, be careful:
  • in case of breakage, use a lighter to burn off the enamel that insulates the wire
  • tie the pieces back together tightly
  • it doesn't hurt to check the repaired connection with multimeter
- once finished, tape down the coil.
- leave 10 - 15 cm on the outside, too
- burn off about 1 - 2 cm worth of the enamel and the end of each coil with a lighter (just be careful with thin stuff, since it will burn up really quickly--a quick pass with the flame should suffice). Use fine sandpaper to take off anything that stays on.
4 comments
May 14, 2009. 4:44 PMSoulReaper18 says:
ok i know you must have done ALOT of Turns on these bobbins... ALOT! haha can you round a number in telling me?
Jan 14, 2009. 4:34 AMcomodore says:
I found this site that sells all kinds of magnet wires...
http://www.bulkwire.com/product.asp?ProdID=7589
Would a 36 gauge Weight: 1/4 lb. Length: 3092.5 ft do fine???
I want to buy this one, so I want to consult you will this do for your project????
Thanks a lot!
Jan 10, 2009. 5:24 AMcomodore says:
What is the material on whitch the wire is vinded, metal or plastic??? From the picture I would say metal...
Dec 13, 2008. 12:03 PMGriffin21 says:
Im using 24 gauge will this hurt the voltage and everything else? I couldnt find anything higher than 24.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:mikejedw
I am an MFA student in Parsons Design and Technology department. I specialize in physical computing, games, mobile applications, and weird little toys.
