3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Print Waterproof Plastic Maps
Make your own Waterproof Maps by Printing directly on Plastic Film...garbage bag film.  This is not simply laminating paper maps.
The end result of this simple project is a 100% plastic map that is thinner, lighter, and more durable than paper.
Sure, plastic paper can be purchased for printing water resistant maps however, it is expensive, and usually thicker and stiffer than regular paper; making it difficult to fold into a pocket sized, ready reference.
This process produces a map that is only slightly thicker than a garbage bag; that is waterproof, and best of all, can be folded (or crumpled) without damage for stuffing in a pocket.
Step 1Size and Weight Matters
Water is the nemesis of printed paper maps.  It creates a pretty rainbow effect as the ink bleeds into the paper.
Nice abstract art but, useless for orienteering.
I like to print my own maps of an area when we go hiking. A trail map, and maybe a topographical (Topo) map, and  a road map for directions to the trail head or pick-up point.
The approach used for years, to keep hiking maps from the elements involved storing them in a zip top plastic bag. Folded into quarters, it looks like the map on the left below.  It keeps maps dry, however, the folded baggie only seems to fit in the square shaped pockets of cargo pants, and eventually, the folding and unfolding takes its toll on the bag and the paper inside.
Also, There is always a chance the maps will get wet every time the bag is opened.  And many times, the bag has to be opened to shuffle through multiple pages for various sections of the trail.
For the most part, this method works, and I will probably continue to carry master maps in this fashion.  But, sometimes, especially when traveling in familiar areas, all that is needed is a quick glance at a map to confirm the trail you want is to the left or right ahead.
This is where this Instructables map technique excels... A ready reference thin enough to be stuffed in a pocket, durable enough to survive multiple crumpling and best of all...weatherproof.
It is important to understand the limitations of this process.
Plastic film shrinks when heated so, the map scale will no longer be correct (i.e. a 1/4 inch will no longer equal a mile, etc.)
The fidelity of fine map details may be difficult to discern. Printer ink does not absorb into the plastic film so, the surface tension of the ink will will blur small text and fine details.
Despite these drawbacks,  this process will produce a reusable map suitable to tuck in a shirt pocket for reference on the trail in the worst weather, or as a very compact emergency back-up map tucked away in a survival kit.
63 comments
1-40 of 63next »
Apr 29, 2012. 7:04 PMchaitanyak says:
Impressive!
Apr 2, 2012. 8:34 PMcory.smith says:
Very Cool. Never would've thought to try something like this.
-Cory
Dec 15, 2011. 12:27 PMmadmanmoe64 says:
You could run these through a laminator (without the thick plastic) to bond them, more even pressure and less hassle than ironing.
Feb 8, 2012. 9:24 AMRaNDoMLeiGH says:
I was thinking the same thing!
Freezer paper is also a good substrate for running things through the printer. I think you would still want to pre-shrink the garbage bags, but if you happened to have some other non-shrinkable plastic you wanted to use, you could stick it to the freezer paper. Just iron it, same way - the shiny side is wax, so put something underneath it to avoid mussing your ironing board. It won't delaminate until you pull it off.
Using tissue paper (stuck to freezer paper) plus the baggie idea would yield a lightweight map without the hassle of smeary ink. Do baggies laminate to themselves? I'll have to try that... many applications if so. I know you can use them with a heat sealer, so maybe if you run it through the laminator on super-hot. (Or just iron it to melt it.)
There's also a substance called "bubble jet set" which will allow you to inkjet print onto fabric and it will be waterproof. I've used it myself and while I wouldn't necessarily trust it for a long-term T-shirt, it should work quite well for a map. Men's hankerchiefs would be lightweight and still have enough thread to produce enough detail.
Cool instructable!
http://www.bryerpatch.com/faq/bjs.htm - bubble jet set
Mar 9, 2012. 11:07 AMstar folder says:
Yes, bags laminate to themselves. Just iron between sheets of parchment paper to keep from sticking to the ironing surface and the iron. When several layers are so laminated, you can make a bag - all ironed together.
Feb 2, 2012. 8:47 PMsolagoddess says:
I think this is a super idea, to keep wet things in a wet fabric without it getting moldy . Please can you tell me the name of the product you use or the brand so, I can give it a go? is it the same fabric like those city maps that are around? I will probably have to buy it online as I live in Australia and we don't seem to be able to get some things here.
Jan 13, 2012. 5:08 AMRybka30 says:
this is great idea even for logbook for geocaching :D :D :D
Dec 19, 2011. 6:02 AMMigs says:
So why not just print a map and laminate it with clear lamination plastic that comes in huge rolls for real cheap? The lamination plastic has an adhesive that will bond to the paper, and even fine detail will be visible. I just searched for "laminating roll" in Amazon and there are a ton of options.
Jan 13, 2012. 12:45 AMcanucksgirl says:
I think your project is cleaver and innovative, however I do agree with Migs. You can buy self laminating sheets if not from a roll. They aren't very thick and can easily laminate a map without a lot of bulk. Done this many times.
Jan 12, 2012. 6:09 PMmarinermcv says:
Great Idea! Will try it out on NOAA's Booklet Charts for help Navigating
Coastal Waters.
Jan 12, 2012. 1:24 PMDaddyQ says:
Absolute genius. Had to show my long suffering girlfriend because it's such a good idea.
Dec 31, 2011. 7:34 PMcobourgdave says:
This is a great instructable, really innovative, and a very practical idea.
I will certainly try this one!
Dec 18, 2011. 11:51 PM9w2xyz says:
In an emergency, spray it with a fine oil mist. That keeps it from getting waterlogged. You can also use it to start your fire.....
Dec 17, 2011. 6:17 PMbullfrogs says:
What an interesting idea.
However I have been printing Astronomy maps for years for nighttime usage by printing on plain copy paper(Cheap)!!!! and spraying with quick dry clear lacquer , then let dry for 10 min in the oven and it is permainately waterproof and fold-able.
bullfrogs
Dec 12, 2011. 4:22 PMfrisbeechamp1983 says:
was that map for Philmont? or northern Tier?
Dec 13, 2011. 6:54 AMlittlewit says:
Philmont is the only "Scout Ranch" because it is an active cattle ranch. Northern Tier is a "high adventure base." Good catch, though, I didn't even notice that.
Dec 16, 2011. 2:02 PMB2BSurvivor says:
NO, more Scout Ranches out there. Google "Spanish Peaks Scout Ranch" for one of several.
Dec 15, 2011. 8:00 PMinsignia96 says:
This is a map of the D-Bar-A Scout ranch in Michigan, no idea why the author took the time to cover it up so carefully.
http://www.glcscouting.org/camping/d-a/index.html
Dec 16, 2011. 3:20 AMmokee says:
Well, I tried it and my printer just made a big mess on the plastic, What did I do wrong?. My ink just won't print on the plastic.
Dec 16, 2011. 12:44 AMderte84 says:
Perfect for my next trekking in the netherlands!
Dec 16, 2011. 12:38 AMPepperNetworks says:
The comment about hacking a laser printer to disable the fuser is valid. I know a few craftspeople who took an old laser printer to a repair shop to have the fuser disabled in a way that the printer still thought it was working.
What that accomplished was to prevent the toner from fusing to the paper. Make sure to choose a printer that spits the paper out face-up, because the toner will just be sitting on the paper. You can blow on it or brush a finger across it and the toner will move around like a sand painting.
What it's good for is you now have a loose layer of toner held onto paper by nothing more than static electricity. If you print the image reversed, and then lay the paper on a piece of wood, the toner will transfer to the wood. The guy I saw make the best use of this technique would then carve a person's likeness, or their dog, or a favorite design into a desk sign or plaque, or whatever you wanted. He couldn't draw a lick, but he could sure trace the lines of the printed image!
This is also good for making the name 'chops' like the Chinese use to sign documents. (I worked in Taiwan for a while.) When you're carving the little stone stamp, you don't want to get done to find out that a character is backwards, so some of the shops that make them have the hacked printers. They print the design right-ways, and pick up the toner on the bottom of the stone. Then when they are done carving, they know the design will be right.
How it could be used here is that you could transfer the toner to the white plastic, add the clear and then make one sandwich to iron. All the shrinkage would occur to both pieces of plastic at the same time, so distortion should be minimized, and it keeps you from running plastic through your printer.
I think for inkjets, the ible is the best possible way. I thoroughly agree that using pre-shrunk plastic is good. I am mainly bringing this up to tell people about the toner transfer capability of a hacked laser.
Dec 15, 2011. 11:04 PMLongLongBow says:
I may suggest something about laser printer option. I used laser printer for circuit designs for a while. What I do is actually having an mirrored image of the circuit, print in on shiny coated paper with maximum toner setting and then I put that paper on copper board and iron it. At the and toner is transfered to the board with some paper leftover. I wipe paper with water and it ends. Toner holds on plastic very well so one may use this technique for map printing too I guess.
Dec 15, 2011. 8:01 PMdougbyte says:
YOU ROCK! That is a really, really cool instructable! Thanks for sharing
Dec 15, 2011. 2:51 PMmt4b3n says:
Hey, great tutorial... Though I wonder what's wrong with buying laser- or inkjet-compatible synthetic paper and printing directly onto that? I'm sure you've thought of that, just wondering if you have any advantages in your technique (besides the fun of doing it, of course!).
Also, how well does your map react to being repeatedly folded and refolded?
Dec 15, 2011. 2:43 PMbuilding_boy says:
Awesome idea!
Fantastic ible!
Dec 15, 2011. 2:26 PMsabr686 says:
Great ible. This map can be illuminated from either top or bottom, if needed. If you're extra paranoid, you could even put the finished product inside a freezer Ziploc bag, just in case. Redundancy is the key to survival! That's why I carry more than one method of fire-making, or lighting, and more than one knife.
I'm going to try this ible this afternoon. I know I can find something that needs printing!
Dec 15, 2011. 2:26 PMcmjake007 says:
one of the very best on this whole site. I have made a point of storing away in my head and am sure sooner or later this information will solve a problem or two.. Now it is time to figure out more places this process will be useful. Does this site give prizes ?? if not, it should, and this deserves recognition. thank you.
Dec 15, 2011. 2:08 PMmokee says:
That's wonderful and I was just wondering last night how to make a paper waterproof without making it too thick. thanks so much, I can hardly wait to try it
Dec 15, 2011. 1:36 PMEndante says:
Wonderfully done!
An awesome example of an instructable done right.
Clear photos, with notes as to what to be looking for in important ones.
Clear instructions with the important points and possible "gotchyas" clarified and in bold to make sure they are not overlooked.
I look forward to sharing this with a local hiking club!!
Dec 15, 2011. 1:24 PMmidsummermuse says:
Awesome!
Dec 12, 2011. 10:57 AMkostya says:
Impressive technique! Will it work with a laser printer? Thanks a lot for sharing.
Dec 15, 2011. 8:11 AMtobybirch007 says:
You might be able to hack into the laser printer and disable the heater that melts the toner. Then use your method to fuse it together, possibly eliminating the need for the clear layer.
Dec 15, 2011. 10:43 AMarpruss says:
But with a laser printer there is less need for this hack, since there is no ink to run.
Dec 15, 2011. 12:09 PMcriggie says:
I used to have a pack of paper from HP... Was called something like Tough paper.
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06c/A10-12771-215517-3445098-3445098-29779-29781-29782.html
That stuff was about $2 a page, but you could not rip it. It was not proof against sissors though.
Excellent substitute for a laser printer.
Dec 15, 2011. 12:07 PMFightCube Technologies says:
"DO NOT create a double-decker "sandwich" " I don't know why, but this made me laugh out loud! Cool project!!
Dec 15, 2011. 11:28 AMWVSundown says:
Great Instructable! I'll have to try this very soon.
Thanks very much!!
Dec 15, 2011. 11:08 AMray.dora says:
Have you ever tried prinitng directly on Tyvec or other sihpping/house cover material. Even though they are plastic, they're still 'fiborous' like paper. I can't wait to try it and try you're method - Thanks!
1-40 of 63next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
609
Author:hpstoutharrow
