loading
Step 3: Cut the White Plastic Film
Cut a White Film Blank from a white kitchen garbage bag.
The White Film Blank should approximatly 10 inches by 7 inches.
The blank is purposely cut smaller than a standard 8.5 x 11 inch letter sized printer paper.
This is to avoid the plastic potentially overhanging the paper, and coming in direct contact with the hot iron.
Note:  When cutting through the garbage bag, there will be to two sheets stacked together, be sure to seperate the two ply blank.
Only a single thickness of the white plastic film is required.
great idea.
<p>I often use Water Seal (Thompsons or Olympic) and just paint it on maps - either USGS or software-printed maps. The water seal soaks through the fibers and you end up with a &quot;Write-on-the-Rain&quot; material - can write on with pen or pencil, folds, and is more resillient than plain paper. A gallon is about $15 bucks (compared to $10 for 4oz of some commercial &quot;Map Seal&quot;) and you can do a gazillion maps.on a gallon.</p><p>Tip- paint them on something you don't mind water sealing, since the sealant soaks through the paper. I do it on my picnic table and kill two birds with one stone.</p>
What an interesting idea.<br>However I have been printing Astronomy maps for years for nighttime usage by printing on plain copy paper(Cheap)!!!! and spraying with quick dry clear lacquer , then let dry for 10 min in the oven and it is permainately waterproof and fold-able.<br>bullfrogs
<p>may I ask why the drying in the oven? Must it be a a certain temp</p>
<p>If you use a warm oven (~250F) it dries quickly and the ink doesn't have time to bleed. Amateur astronomers and scouts have been using this trick for years. As clever as this 'ible is (and it is), the spray can laquer trick gives better results with a lot less effort.</p>
Awesome ible. I cant wait to try it.
Judging by the Scout Ranch being the name of the map, i'm guessing this is a map of Philmont?
thank you for a great idea and a good looking instructible! you know you could use this technique for things besides maps: maybe photos to take on a long trek (if shrinkage is the same in both directions, though could be fun in a different way if distorted) or important info like instructions or phone numbers, or an itinerary for a workout or swimming, or an inspiring quote you really like to take *everywhere* you go. or copy a drawing (do inkjet printers come as 3 in ones? if not, then scan and print separately) which might be a great way to send kids' art to a mom or dad in the military. or even draw right on the plastic with markers. lots of possibilities for art.
Cool idea and wonderfully explained. There aren't a lot of instructables that can be so easily followed. <br> I had an idea as far as the print detail goes. haven't tried it on your process but maybe it would work. I remember buying raw shrinky dink material and trying to do colored pencil drawings on them. The surface is pretty slick and didn't allow the color to stay on. So I lightly sanded the surface to be colored with fine sandpaper to give it a bit of texture. Maybe it could work her. But I don't know if that would work on the thin garbage bag to correct the ink issue. <br>Anywho....Great instructable! and Cheers!
I have tried the process twice now to no avail. I just can't get the ink to show through the clear plastic....don't know where the heck it goes, but it just disappears at the second lamination point.
Totally brilliant, it only happened to me just once, gonna try this next vacation trip!
So why not just print a map and laminate it with clear lamination plastic that comes in huge rolls for real cheap? The lamination plastic has an adhesive that will bond to the paper, and even fine detail will be visible. I just searched for &quot;laminating roll&quot; in Amazon and there are a ton of options.
Laminating film is usually a heavier weight plastic (and more expensive) The thickness of a front and backside laminated sheet of paper has a thickness that will not fold readily. At that point, its the same bulk as a map in a folded zip top bag. <br> The real advantage of this instructable is that it produces a map that can be stuffed in a pocket without the bulk. Folding will not create dammaging creases or delamination. The map is as thin and flexable as a plastic baggie. <br>
I think your project is cleaver and innovative, however I do agree with Migs. You can buy self laminating sheets if not from a roll. They aren't very thick and can easily laminate a map without a lot of bulk. Done this many times.
And I disagree - self laminating sheets are fare more bulky that the OP's creation.
I think this is a super idea, to keep wet things in a wet fabric without it getting moldy . Please can you tell me the name of the product you use or the brand so, I can give it a go? is it the same fabric like those city maps that are around? I will probably have to buy it online as I live in Australia and we don't seem to be able to get some things here.<br><br>Thanks :-)
Read the instructable - it's just a white kitchen garbage bag and a freezer sized resealable bag. You can buy those products in just about any country.
Awesome instructable. I am making a bunch for my local Volunteer Search and Rescue unit, of which I am a member. You have saved us a bundle, Kudos to you.
Impressive!
Very Cool. Never would've thought to try something like this.<br> <br> -Cory
You could run these through a laminator (without the thick plastic) to bond them, more even pressure and less hassle than ironing.
I was thinking the same thing!<br> <br> Freezer paper is also a good substrate for running things through the printer. I think you would still want to pre-shrink the garbage bags, but if you happened to have some other non-shrinkable plastic you wanted to use, you could stick it to the freezer paper. Just iron it, same way - the shiny side is wax, so put something underneath it to avoid mussing your ironing board. It won't delaminate until you pull it off.<br> <br> Using tissue paper (stuck to freezer paper) plus the baggie idea would yield a lightweight map without the hassle of smeary ink. Do baggies laminate to themselves? I'll have to try that... many applications if so. I know you can use them with a heat sealer, so maybe if you run it through the laminator on super-hot. (Or just iron it to melt it.)<br> <br> There's also a substance called &quot;bubble jet set&quot; which will allow you to inkjet print onto fabric and it will be waterproof. I've used it myself and while I wouldn't necessarily trust it for a long-term T-shirt, it should work quite well for a map. Men's hankerchiefs would be lightweight and still have enough thread to produce enough detail.<br> <br> Cool instructable!<br> <br> <a href="http://www.bryerpatch.com/faq/bjs.htm" rel="nofollow">http://www.bryerpatch.com/faq/bjs.htm</a> - bubble jet set
Yes, bags laminate to themselves. Just iron between sheets of parchment paper to keep from sticking to the ironing surface and the iron. When several layers are so laminated, you can make a bag - all ironed together.
this is great idea even for logbook for geocaching :D :D :D
<br>Great Idea! Will try it out on NOAA's Booklet Charts for help Navigating<br> Coastal Waters.
Absolute genius. Had to show my long suffering girlfriend because it's such a good idea.
This is a great instructable, really innovative, and a very practical idea.<br>I will certainly try this one!<br>
In an emergency, spray it with a fine oil mist. That keeps it from getting waterlogged. You can also use it to start your fire..... <br>
was that map for Philmont? or northern Tier?
Philmont is the only &quot;Scout Ranch&quot; because it is an active cattle ranch. Northern Tier is a &quot;high adventure base.&quot; Good catch, though, I didn't even notice that.
NO, more Scout Ranches out there. Google &quot;Spanish Peaks Scout Ranch&quot; for one of several.
More Scout Ranches than you think...
This is a map of the D-Bar-A Scout ranch in Michigan, no idea why the author took the time to cover it up so carefully.<br><br>http://www.glcscouting.org/camping/d-a/index.html
Well, I tried it and my printer just made a big mess on the plastic, What did I do wrong?. My ink just won't print on the plastic.
Perfect for my next trekking in the netherlands!
The comment about hacking a laser printer to disable the fuser is valid. I know a few craftspeople who took an old laser printer to a repair shop to have the fuser disabled in a way that the printer still thought it was working.<br> <br> What that accomplished was to prevent the toner from fusing to the paper. Make sure to choose a printer that spits the paper out face-up, because the toner will just be sitting on the paper. You can blow on it or brush a finger across it and the toner will move around like a sand painting.<br> <br> What it's good for is you now have a loose layer of toner held onto paper by nothing more than static electricity. If you print the image reversed, and then lay the paper on a piece of wood, the toner will transfer to the wood. The guy I saw make the best use of this technique would then carve a person's likeness, or their dog, or a favorite design into a desk sign or plaque, or whatever you wanted. He couldn't draw a lick, but he could sure trace the lines of the printed image!<br> <br> This is also good for making the name 'chops' like the Chinese use to sign documents. (I worked in Taiwan for a while.) When you're carving the little stone stamp, you don't want to get done to find out that a character is backwards, so some of the shops that make them have the hacked printers. They print the design right-ways, and pick up the toner on the bottom of the stone. Then when they are done carving, they know the design will be right.<br> <br> How it could be used here is that you could transfer the toner to the white plastic, add the clear and then make one sandwich to iron. All the shrinkage would occur to both pieces of plastic at the same time, so distortion should be minimized, and it keeps you from running plastic through your printer.<br> <br> I think for inkjets, the ible is the best possible way. I thoroughly agree that using pre-shrunk plastic is good. I am mainly bringing this up to tell people about the toner transfer capability of a hacked laser.
I may suggest something about laser printer option. I used laser printer for circuit designs for a while. What I do is actually having an mirrored image of the circuit, print in on shiny coated paper with maximum toner setting and then I put that paper on copper board and iron it. At the and toner is transfered to the board with some paper leftover. I wipe paper with water and it ends. Toner holds on plastic very well so one may use this technique for map printing too I guess.
YOU ROCK! That is a really, really cool instructable! Thanks for sharing
Hey, great tutorial... Though I wonder what's wrong with buying laser- or inkjet-compatible synthetic paper and printing directly onto that? I'm sure you've thought of that, just wondering if you have any advantages in your technique (besides the fun of doing it, of course!).<br><br>Also, how well does your map react to being repeatedly folded and refolded?
Awesome idea!<br><br>Fantastic ible!
Great ible. This map can be illuminated from either top or bottom, if needed. If you're extra paranoid, you could even put the finished product inside a freezer Ziploc bag, just in case. Redundancy is the key to survival! That's why I carry more than one method of fire-making, or lighting, and more than one knife.<br>I'm going to try this ible this afternoon. I know I can find something that needs printing!
one of the very best on this whole site. I have made a point of storing away in my head and am sure sooner or later this information will solve a problem or two.. Now it is time to figure out more places this process will be useful. Does this site give prizes ?? if not, it should, and this deserves recognition. thank you.
That's wonderful and I was just wondering last night how to make a paper waterproof without making it too thick. thanks so much, I can hardly wait to try it
Wonderfully done! <br> <br>An awesome example of an instructable done right. <br> <br>Clear photos, with notes as to what to be looking for in important ones. <br>Clear instructions with the important points and possible &quot;gotchyas&quot; clarified and in bold to make sure they are not overlooked. <br> <br>I look forward to sharing this with a local hiking club!!
Awesome!
Impressive technique! Will it work with a laser printer? Thanks a lot for sharing.
Be very cautious with a laser printer. The heat used to fuse the toner ink to the paper will likely reek havoc with the plastic film bonded to the paper. Would hate to gum up the inner workings with melted plastic.<br><br>I would not recommend...however, that is what experimentation is all about....maybe even better results.
You might be able to hack into the laser printer and disable the heater that melts the toner. Then use your method to fuse it together, possibly eliminating the need for the clear layer. <br>
But with a laser printer there is less need for this hack, since there is no ink to run.
I used to have a pack of paper from HP... Was called something like Tough paper.<br><br>http://h10010.www1.hp.com/wwpc/us/en/sm/WF06c/A10-12771-215517-3445098-3445098-29779-29781-29782.html<br><br>That stuff was about $2 a page, but you could not rip it. It was not proof against sissors though.<br><br>Excellent substitute for a laser printer.
About This Instructable
126,774views
631favorites
License:
More by hpstoutharrow:New Year's Tree Print Waterproof Plastic Maps Volcano Picnic Plate
Add instructable to:
