Introduction: Print on Toilet Paper
An easy way to use your home printer to print on your toilet paper
Step 1: Things You Will Need...
- A standard piece of printer paper
- A roll of scotch tape
- A printer
- A computer
- 2 sheets of toilet paper
Step 2: Prepare Your Document
You can print just about anything, as long as you keep the margins under 4.5 inches across. The closer your letters are more than 4.5 inches across then will fall off your toilet paper.
In word:
Go to the page layout tab
Click on margins
Click on custom margins
Enter 2.5" into the left margin box
Enter 2.5" into the right margin box
Press OK
Step 3: Prepare Your Paper
Place the toilet paper as near to the center of the paper as possible, the more accurate the better your final product will look, you could measure it, the edges should be 2.5" apart. Then tape the toilet paper to the top and bottom of the paper, this should hold the corners and edges down. You really don't need to tape the edges but make sure the toilet paper is taut and flush to the paper.
Step 4: Placing the Paper in the Printer
Place your paper with the toilet paper on it into the paper upside down in the paper input part of your printer.
Step 5: Print!
Then all you do is hit print on Word!
(sorry no picture)
Step 6: The Result
You should have some toilet paper that has words in it!
Words of Warning: NEVER put just toilet paper in the printer, you will get the worlds worst paper jam
If the tape is not secure you could get a bad jam
The print heads could deliver unwanted ink in unwanted places, nothing you can do about this
Step 7: Removing the Toilet Paper
To remove the toilet paper from the printer paper you can do a few things:
You could use an x-acto knife and cut below the tape
You could peel the tape off the paper and then press it to the back of the toilet paper
You could cut the tape at the edge of the toilet paper
i, personally, like the first method.
bree dee dee dee dee dee de de de de de de
