Print With Advanced Filaments | DIY Simple Low Cost Extruder
Introduction: Print With Advanced Filaments | DIY Simple Low Cost Extruder
You can review the first version of atom extuder from here
We designed this extruder to be
- Simple and easy to build
- Low cost
- Compact design
- Low weight
- Small footprint
- Wire management
- Easy to mount
- One active cooling fan for both heat sink and nozzle tip
- Open source
- Can print with various type of filaments
- Advanced filament materials
- Copper, Bronze, Wood, Glow filaments
- Designed to print with flex materials
By following the next 3 simple steps you will be able to build your own.
Step 1: Prepare the Bill of Materials
Step 2: Get the 3mm Plywood Layout
Step 3: Follow the Assembly Instructions
You can download the complete source file from
We are trying to make our tutorials simple and easy, so please if you found any information were missed kindly inform us.
Follow us for more on
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    So, the B.O.M. has no measurements and after ordering a few parts that don't work and then using the measuring tool in an STL Viewer, I thought I'd post my findings so no one else makes the same mistake.
    The U-Groove Bearing is a 4mm(ID)*13mm(OD)*4mm(w). I found them on Amazon here:
    The heatsink I'm still looking for, the first one I tried was this one:
    It's dimensions are 50mm(h)*25mm(w). After using the measuring tool, it looks like the heatsink being used 13mm(h)*14mm(w), although you might be able to get away with it being 20mm(w).
    The drive gear is 11mm(w) but I'm using a 12mm(w) and so far it seems to be ok. Here it is on Amazon:
    Also the heatsink can only be around 15mm(h).
    الله ينور يا هندسه واللهي
    Hi! I was wondering how to 100k thermistor was attached to the 40 watt heater, and in addition, whether there was a certain brand/model of heater you recommended. Thank you for your excellent tutorial!
    In addition, the parts list calls for a NEMA 17 motor while the image shows the one you're using as a 16; would either work? Thanks!
