Printed Shower Knob
Introduction: Printed Shower Knob
The shower knob in our guest bathroom was spinning freely, so I needed to do something fast.
I quickly came up with a design that will work using 123D software (free).  The design and print files are available at:
Step 1:
Life is not perfect.  The hole in my first knob was too small.
Step 2:
Rather than redo my 30 minute design, I just "enlarged" the print to 119%.
Step 3:
The hole worked, but I had left too much "shoulder" inside and the screw wouldn't fit.  I did a two minute design tweak and printed again.
Step 4:
Put the knob on and screw it in.
Step 5:
Because my knob is long and does not contain a "stop" to limit its travel, I wrote the word "off" at the top shutoff position.
Beauty and a "stop" are desirable upgrades for the knob, but this is functional, costs about one dollar, and is more socially acceptable than a pair of vice grip pliers.
As a follow up, I found a way to repair the old knob:
    • Epilog Challenge 9
      Epilog Challenge 9
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    This is great !!!. I had the exact problem once and ended up filling the broken knobndle with automotive "Bondo" and letting it cure on the shaft. Still works after 9years.
    I repaired my knob using a printed ring based on the idea I got after reading your comment. I did credit you with inspiring the repair ring.
    Thanks! Its always good to bounce ideas around :-).
    You should remove that knob, photograph it and write it up as an instructable. You could enter it in the "Fix It" contest and maybe win a 3D printer . .
    That's a good cure! It gives me an idea--I wonder if I could print a custom size "ring" and hold the broken piece inside the original knob. I'm going to give it a try :)
    Good job on ya! hard work paid off
