Printer to Vinyl Cutter Hack
184,013
1,401
69
Published
Introduction: Printer to Vinyl Cutter Hack
About: Fixer, Finder, Fabricator.
Vinyl cutters are used in the sign writing industry, and are great for making stickers, signs and graphics. I would like to thank Instructable  members silverjimmy  and Groover for their fantastic laser cutter instructables, without which I would not of been able to complete this project.
My idea is to take an old printer and turn it into a vinyl cutter, as they are quite similar in there design and it would hopefully make the build just that little bit easier.
As most people find the electronics an software the most intimidating part of a project like this, I've gone into a fair amount of detail on how to set it up.  Turns out the mechanical part of this project is far more challenging, as it takes quite a bit of tweaking, adjusting and general head banging to get the vinyl to cut  properly.
The video is of a test run with a marker pen.There is really not that much to see when Its cutting vinyl as its very hard to see where the cuts are until after the the vinyl leaves the machine.
Step 1: Parts You Will Need
I got quite a few of the parts from Core electronics who have lots of stuff and post it out really quickly. The rest I got from ebay which also has lots of stuff, but the post can take 2 or 3 weeks here in Australia especially if the parts come from Hong kong or China.
Step 2: Checking Out the Printer
Of course you will also need a printer, an old one with stepper motors driving the roller and the slide. I pick up this old cannon A2 printer off ebay for $5. Back in the day it would of been worth $2000-$3000. Before I got to carried away striping the printer down I spent a few days thinking about what needed to be removed and what I could keep. First I removed the plastic cover and studied the internals of the printer, I printed a few pages and tried to get a good understanding on how everything works.
The covers came off quite easily just a knob on the side and a few clips and it all came apart.
If your not sure if you have stepper motors or normal dc motors they are quite easy to identify, steppers have 4 or more wires coming out the back and they are  usually quite a large diameter and short. So look for short and fat motors with 4 wires.
Step 3: Mounting the Arduino, Easy Drivers and Relay
The first thing to do is to work out where the Arduino, relay and easy drivers are all going to fit, so I removed all the old electronics and made up a laser cut board for everything to mount on.
Once that was done it was time to start using some of those dupoint wires, they make every thing very easy to wire up Just pull a pin out of the headers and plug it in if you want to make the end of the wire male.
The next step will show you where all the wires go but first we need to identify the four wires on our stepper motor.
  • Set your multimeter to the 200 ohms setting
  • Grab any 2 wires on you stepper motor and check if you get a reading you should get either open circuit or a low resistance.
  • If it was open circuit, grab another wire and check that, you are looking for a pair of coils inside the motor, so you need to match up to ends of each coil (which are connected  to to each wire)
  • Once that is worked out, I cut a dupoint lead in half and soldered each end on to the matching pair of wires. Because th leads are the same colour I know that is on coil.
  • Repeat the process with other 2 motor leads and the other motor
  • Next I identified the wires coming out of the power supply and the voltage which turn out to be 28 volts.
  • Make sure that you check the polarity of your power supply and wire it up correctly or you will have lots of smoke and swearing. Use a red and black wire.
  • I found that the easy drivers do get quite hot so a bit of thermal grease and an old heat sink helped keep things cool.
Step 4: Wiring Up the Ardunio
The wiring is pretty easy, use your dupont connectors and and start plugging stuff in. First we will look at the easy driver board, many of the pins are not used in this project. In step three we identified  the wiring for the stepper motors, so we can plug them in first.
  • Motor coil A and motor coil B connect to the stepper motor It doesn't matter which way around as long as A goes to one coil and B to the other coil
  • The Power in - +  pins go to the power supply and you need to get these around the right way and up to 30 volts DC
  • On the lower right there are 3 pins GND (ground)  STEP  and DIR(direction). GND  goes to GND on the arduino
  • Note there are usally 3 GRN pins on the ardunio board it doesn't matter which one you use.
  • On the X axis driver STEP goes to pin 2 and DIR goes to pin 5
  • On the Y axis driver STEP goes to pin 3 and DIR goes to pin 6
  • We wont be using the z axis in this project.
Next the relay
  • The vcc pin goes to the 5V ( 5 volt) pin on the arduino
  • The GND pin goes to GND on the arduino
  • The IN1 pin goes to pin 12 on the arduino
All going well you should hear the relay click when you plug you USB cable in and start Grbl, and the easy drivers should light up when the power supply is turned on. If you haven't installed the software yet you might want to leave the power off for now.
Step 5: Installing the Software
If your not familiar with ardunio or CNC machines this is going to be a pretty steep learning curve, but once you have got your head around it, you will find that its not too hard.
Ive loaded most of the software on a Mac laptop, and it works, with the exception of the X Loader which I had to load onto a windows machine. (more on that later)
If you use windows I'm sure it would be easier.
so here's the list
Step 6: Getting the The Arduino and Computer to Play Nice.
Ive put a few screen shots with notes on this step, to make it a little easier.   I could not get X loader to work on my macbook so Ive got the set up for windows.
Once the Arduino board has been flashed with the X loader program you will no longer be able to use it with the Arduino software, however you can then use grbl on windows or a mac.
I have a few screen shoot of the Mac version  of Arduino and Grbl as they are slightly different to the windows version
  • First thing to do is to plug in you Arduino  board and open up the Arduino software to get the board talking to your computer.
  • In the tools pull down tab you will find serial port you can choose from
  • If your not sure which one to choose, go into Start / control panel / system / hardware / device manger / ports (com & lpt)
  • That should tell you which com port to select.
  • Double check that everything is working by running a sketch. On the Arduino software  file / examples / basic / blink.
  • Now hit the arrow button below the "edit" tab  and you should see the Aruduino board light up and a "message done uploading" at the bottom of the screen
  • Now open up Xloader  and select the hex file, the device (uno) and the com port
  • Warning once you hit upload you wont be able to use the Ardunino software on that board.
  • Hit upload and give it a minute or 2  until you see the upload done message.
  • Now open Grbl and choose the com port
  • Once you click on the open button, you should see text scroll down the page
To Install Arduino and Grbl on a Mac its pretty straight forward, but the serial ports are a little differently set up
  • Fist install arduino and go to tools / serial port and choose one of the ports with usb in the name e.g. /dev/tty.usbmodemfa131
  • Run a sketch just like in windows to check everything works.
  • Grbl will not work unless you have installed Ardunio first.
  • Flash you Arduino board using xloader on a windows machine.
  • Install Grbl and choose the correct serial port and every thing should work
Step 7: Modifying Inksape
To get Inkscape to generate a useful gcode we have to install the laser engraver add on and a fiddle with the output path.
Ive done this on a Mac computer but I have since found out it may not work on all mac computers, it depends on what version OS you have.
  • First install Xquartz and  then Inkscape,  the links are on step five.
  • The install can be a bit grumpy so take your time and restart when finished.
  • Once you have inkscape running close it down and go into Applications / inkscape / (right click) / show package contents.
  • You will find a folder  Contents / resources / extensions /
  • Now copy the files  from you laser engraver folder you downloaded . There are  4 files
  • Paste them into the extensions folder and click on "replace"
  • Now open Inkscape and you should have and extension named laserengraver.
  • When you click on it it should pop up with a laser box
  • This step I found the most frustrating. Under the preferences tab you need to type in the path to where you Gcode will be saved. By default inkscape seems to hide the file somewhere Ive never been able to find.
  •  Try  /Users/"yourname"/desktop  I have seen other variations  it depends how your laptop is setup    /Users/volumes/"yourname"/desktop
  • If your Mac still dosnt want to play with Laser engraver try installing eggbot the extension It seem to fix the laserengraver,
Step 8: Test Run With No Blade
About now we a ready to start tuning the software so the machine draws stuff the right size, the right way around and at a reasonable speed. I taped a pen to the side of the printer head and start to play with some setting.
I noticed that the mac version can be a bit gitchy  as the new setting don't seem to work sometimes but hitting the big red close/reset button seems to fix it usually.
If you look on the first screen shot notice the 3 tabs Axis control, Visualizer  and Advanced. There is also a step size tab on the bottom right and arrows to step the X Y and Z Axis
You can make your printer roller and slide move by clicking on each arrow, If things are going the wrong way or moving on the wrong button you can fix this by correcting your wiring on the easy driver to motor connections. To change direction of the motor, reverse the connection on one motor coil.
Warning Dont change any connections with the power on it will damage the easy driver boards.
Time to start playing with the setting. (Notes are also on the screen shots)
  • We need to change The X and Y setting so the slide and paper move the correct distance. Note the $0=250.000(X,step/mm)  and the $1=250.000(Y,step/mm)
  • Click on the advanced tab then click on Unlock Grbl then Grbl setting
  • Click on the stetting you want to change, The roller was travelling way to far so I reduced this to 29.5 ( yours will probably be different) so the paper would move exactly 100 mm when the 100mm step is selected.
  • Hit apply and on the main screen hit soft reset
  • All going well you should see a new line of code at the bottom of the text screen. You can then use the arrows to see if your changes worked. (If nothing changed hit the red reset button)
  • Once you have on axis moving the correct distance you can adjust the other.
  • You can also adjust the speed Under the default feed and default seek
  • You will find that speed doesn't change that much until you adjust the acceleration
  • I got mine setting by trial and error, with the goal been to draw a 100mm square box, it to about an hour of fiddling
  • I then found it was all back to front so a quick wiring change to the X (slide) stepper motor fixed that.
Step 9: Adding a Surface for the Blade
The blade needs a surface that is slippery and a bit softer than steel so that it is not damaged when cutting. I used a strip of plastic with double sided tape, just make sure that it is perfectly flat and the is no sharp edges for the vinyl to get caught on.
Step 10: Removing Unnesary Hardware
I found that there was a few things that could be removed as they were just creating drag as the spun with the roller. So the tractor drive was removed and a couple of gears also.
Step 11: The Electromagnet
The electromagnet was removed from a 24 volt automotive relay  and is used to pull the cutter down onto the vinyl. Its just a case of removing the cover and pulling the contacts off, so you end up with a coil. This is then wire back to your power supply and the relay attached to the Arduino is used to control it.
The internals of the printer head are removed and after some trimming, cutting and careful positioning the coil can be put in place.To test it you can use the spindle on tick box in grbl and this will turn the relay off and on.
Positioning the coil is quite difficult  as it need to be square, flat, and not quite touching the cutting plate when energized. I spend quite a bit of time getting it just right before gluing it down with rapid fix super glue.
Just a note on the rapid fix super glue, if you can get it it is the best glue that I have ever used. It like super glue on steroids and it comes with a powder  that can be used to fill large gaps or holes
Step 12: Fitting the Cutter
As with the electromagnet,  this part was also very time consuming and fiddly. I used a 3D printer to make a holder for the cutter and also some little brackets to hold the tube and spring from a ball point pen. The idea of the pen spring is to lift the cutter off the vinyl when the magnet is not energized,
Again everything has to be aligned perfectly and the spring tension has to be just right so the cutter moves away from the vinyl but not so far that the electromagnet is unable to pull it back.
I made an interesting discovery, that is I placed a button rare earth magnet on the back of the electromagnet it made the electromagnet much stronger and work more reliably. (This is a bit hard to see in the photo I've put a note box  on the photo with the yellow vinyl)
I then used the rapid fix glue to fasten everything down.
I also found that as the printer has a couple of gears in the mechanism, the tiny amount of backlash they  have, was causing some of the cuts not to join up by about 1/2 a mm. Very annoying when you go to remove the wast from the sticker, so I will move the stepper motor so it directly drives the roller.
Step 13: Work Flow
To put a drawing on the vinyl cutter is a bit of a process, and not all drawings are suitable to turn into a sign or sticker. Cartoons or block letters work best and the file cannot be too small or pixelation will cause issues.
The Screen shot have notes.
  • Open up Inkscape and click on file/ document properties
  • Next change the default units from px to mm you need to do this in 2 places
  • Now File / Import your drawing and select the drawing you want
  • A box will pop up just click ok
  • Your image should appear on the page and can be moved or re-sized The cutter starts from the lower left corner so you want to make sure its moved close to that point
  • Under the path tab click on trace bitmap
  • A pop up box with lots of settings to play with will appear click on update and ok when you are finished. The image should be made of  solid blacks lines when finished.
  • When you go back to your image on the page it looks like nothing happened, drag the trace off the top of the original image
  • Now delete the original image and move it to where you want on the page (macs have no delete key use control delete)
  • Now under path click on object to path
  • click on extensions Laserengraver
  • In the pop up box make sure the Directory path is correct and click on the laser tab
  • Turn the speed up to 1000 but dont click on apply yet. There is a glitch here that cause an error if the laser tab is open
  • Click on preferences again now hit apply
  • You should get a laser working box and a Gcode will appear on you desk top
  • If you would like to the workings of a Gcode you can open it with text edit
  • Open up Grbl and click on choose file and find your Ggode
  • You will now be able to see your tool path
  • Once you click on "begin", the machine will start working, you can follow the tools progress with the red dot and green lines on the screen
Step 14: Applying the Sticker
Its tempting to start ripping off the waste from your sticker as soon as it comes out of the machine, but if you have lots of detail on your sticker (like the robot) that's the last thing you want to do.
If you pull off the wrong piece or get some of the waste stuck on the rest of the sticker, or a part hasn't  quite cut right and you pull that off, its very difficult to fix and in most cases you will have to start again. So here my top tips for success.
  • Start from the outside, and if the waste is quite large cut it into smaller pieces with a sharp knife or box cutter before you pull it off
  • Be very aware of where the waste is (I screw it up into a ball as I'm working) It only takes a a second for it to touch your sticker and it nearly impossible to remove.
  • As you peal pieces off some  small parts may be lifted off as well  so take your time and use your knife to push these parts back on to the backing paper.
  • Use a small knife to flick and small pieces out and it doesn't matter if you damage them sometimes stabbing a piece its the best way to remove it
  • As soon as you have finished removing the waste, cover the sticker with masking tape as this will protect it from damage and it is now ready to apply
  • Clean and dry the surface you want to apply the sticker to.
  • Carefully remove the masking tap and the sticker will come off with it.
  • Apply the sticker to the surface and watch out for wrinkles
  • Rub it down with your fingers and slowly start pulling the masking tape off.
  • Sometimes parts of the sticker will want to come off with the tape, just push it back down and rub it again and pull the tape off from a different direction.
  • Once the tape is off rub the sticker down with your fingers.
Arduino Contest
Runner Up in the
Arduino Contest
Full Spectrum Laser Contest
Third Prize in the
Green Electronics Challenge
Second Prize in the
  • Clocks Contest
    Clocks Contest
  • Planter Challenge
    Planter Challenge
  • Oil Contest
    Oil Contest
1 Questions
I recently picked up a Roland STX8 and I was wondering if I would only need to replace the board ( and put a arduino in) since it is already a vinyl cutter. I would really like to use this cutter with new software.
Also, since this post was in 2018, would you recommend any upgrades? the arduino is only 11.99 now and I was hoping that's all it would take to make this project happen.
69 Comments
great write up! Im in the process of gathering parts for my XY plotter/cutter upcycled from an old plotter. DC encoded motors, endstops, and Z axis. I was going to retrofit nema 17s but after continually researching, i am confident that either my KFB2.0 or soon to arrive Mega will be able to handle these with either a quadrature shield or something. if I can control all of these encoded motors, it will make completing this project more likely.
Step5 installing software..
Is it i just use which one i want use or i must use all that you list in there? Tq
I acquired a chinese vinyl cutter which i have spent what feels like an eternity trying to handshake with my computer and multiple softwares to no avail. it just wont connect. my question is can i whip out the serial board which has a 24pin lpt socket and a 9 pin com socket and replace it with a usb board from an old printer and user the drivers for that printer and send images from adobe software like AI or photoshop. or will i need to use another board and cnc software instead. it would be simpler if i could use adobe for my projects and advice is appreciated , im down to my last hair folicle
Hi,
Ive also bought a Chinese vinyl cutter, and best advise I can give you is use windows XP.
Any other version can cause problems.
I would not try and modify it as they do work they just can be a pain to get set up the first time.
ok cheers i will give xp a go if i can find a tower or laptop with it on :)
I used this guide to refit a cricut expression 2 with an arduino controller. What is the g-code for lifting the spindle back up?
I havent played around with this for ages, I used a plugin on inkscape for laser cutters, have a look in the pictures and notes in step 13
can it be used for make stencil ? on some kind of plastic sheet, by example?
I wouldn't think so, the stencil would have to have a backing like a sticker
instead of relay can i put a another stepper motor from old CD drive that moves leaser to move blade up and down
By coincidence, I had the same printer, but since dismantled it. I have found the psu and steppers from it. I have removed two capacitors from the psu, to repair another psu. Can you supply me the details for C16 & C17 on the power supply?
I intend to convert a Canon i895 printer. Thanks in advance.
Great build!!! Just a question.
How does the knife know when to cut and not to cut? Surely it cant always down or up.
Thanks in Advance.
The program will raise or lower the knife, via the eletro magnet.
A little trick I learned in com tech at school is to stick the tape to your clothes a few times so I gathers some lint as that makes the tape less sticky and easier to remove from the sticker.
Hello!
very good project. I had almost finished it!!! ..but with few problems...
first at all... I can not see the wiring in the "2 relay module" in none of the photos, can you please add me some images of the relay module connections??
thanks a lot in advance!!!
The screw in terminals are the switch side of the relay, there are 3 on each relay common, normally open and normally closed. There are 3 pins you need to use gnd goes to ground vcc goes to 5 volts and IN1 goes to the signal wire on the arduino pin 12 .
thanks! ..but...
that things you tell me I had already done...
I was asking "in what ports" do you connect in the exits of the 2 relay module, and which cables, because in the photos doesn´t seem to be very clear.
I had connected gnd, in1 and vcc pines, that´s ok, the problem is the other side, I connect the 2 positive cables and the 2 negative cables for "power in" the stepper easydrivers, in the "common" exits of the 2 relay module... It seems to work, but don´t cut correctly.
thanks a lot for your help. I hope to be explained well my problem.
The easy drivers have power all the time and are not connected to the relay. The relay, is used to drive the solenoid or coil to move the knife up and down.
OK!!
all done and working!!! thanks a lot for your help!
