3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Printing Magnets with the Roland SP-540V
Here is another installment in my ongoing series of Instructables in which I use equipment that the average reader probably can not afford.
With that stated, I am going to show you how to print magnets using the Roland SP-540V large format printer.
Step 1Prepare yourself.
Prepare yourself.
First off, if you are going to print magnets using the Roland SP-540V you are going to need thin magnet sheeting. Make sure that it is at least 1' wide by 2' long. The printer will be unhappy if you try to feed it anything less.
Next prepare your images using Photoshop, Illustrator or Gimp. If you are using Photoshop or Gimp make sure that you are using an image resolution that is at least 300 dpi. However, the closer you get to 720 dpi, the better your image will most likely print.
To maximize your usage of the magnet sheeting, it is recommended that you space out your different magnets in your image editing software as closely as possible. This will save you the headache of spacing it later and trying to make things fit in all the unused spaces. This file should be nearly as wide as your magnet sheeting since you will always be printing all the way across the length of the magnet. However, allow 1.5" - 2" margins on both ends of its width (see sample below).
Save your final print file as an TIFF (or EPS if you are using Illustrator).
7 comments
Mar 27, 2010. 2:31 PMSDKC says:
Does anyone know a printer that would print on the 30mil magnetic material?
Jan 11, 2008. 6:53 AMEriswerks says:
I happen to have a Roland SP-540V sitting behind me right now... The tech guy who helped us set up this printer told me that although some people do print magnets on it, the magnetic material is so heavy that it really strains the motor, which can damage the printer. If you want to try this, it would be wise to cut a piece to size (+4" in the back so there's enough material for the rollers to grab!) before loading into the printer so that the printer has to do the bare minimum of heavy lifting. You should probably use the lighter 20mil or 15mil magnetic material, too, not the heavy 30mil car magnet stuff. You can get 20mil stuff from Feller's that is intended for cars and has as much magnetic grip as the 30mil. Also, I think cutting with the plotter should be fine. I've done this on a Gerber plotter, and the idea is that you set the pressure just high enough to score the material and go through the white top layer. The black bottom layer can then be ripped cleanly by hand. I'd guess a pressure of about 75 would be good for scoring magnetic on the SP-540V.
Apr 19, 2007. 1:57 AMsuperfli68 says:
Oddly enough I have access to a Roland 540v and magnetic material. However I was under the impression that magnet couldn't be run through the printer. Maybe I can convince my boss to let me try it out. I've had to print vinyl stickers and mount them on the magnet, this will save me so much time
Apr 12, 2007. 7:11 PMJohn Smith says:
I searched the printer, and found that it is $17,000. Is that right? If it is, do you own it?
Apr 13, 2007. 4:20 PMJohn Smith says:
How much are they?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2331
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
