Privacy monitor hacked from an old LCD Monitor
Finally you can do something with that old LCD monitor you have in the garage.
You can turn it into a privacy monitor! It looks all white to everybody except you, because you are wearing "magic" glasses!
All you really have to have is a pair of old glasses, x-acto knife or a box cutter and some solvent (paint thinner)
Here is what I used:
an LCD monitor of course
single use 3D glasses from the movie theater (old sunglasses are just fine)
paint thinner (or some other solvent such as toluene, turpentine, acetone, methyl acetate, ethyl acetate etc)
box cutter (and CNC laser cutter :) but that you don't really need, I'm sure x-acto knife and a steady hand would do just fine)
screwdriver or a drill
paper towels
superglue
Step 1Take the monitor apart
Find an old monitor that you are willing to sacrifice.
Take off the plastic frame by unscrewing all screws from the back.
256 comments
1-40 of 256next »
Feb 13, 2012. 4:20 PMTheGreatS says:
I tried cutting it out by hand (mainly due to the lack of laser/CNC awesomeness lying around) and it worked great. I taped the old lenses to the film (like you suggested) and then cut it out every so slowly with an hobby knife. They don't fall out or wiggle around to much so I'm happy with my result.
Feb 2, 2012. 9:26 AMWakeUpWolfgang says:
Where can I get some polarized film for the glasses the film on my screen is really old and brakes off into small pieces. The only large piece that I have is attached to the mat film and wont come off with out braking up. I did not cut my film off I just took off the metal that was holding the screen together and then you can just peal it off.
Dec 9, 2011. 8:32 PMDyolf_Knip says:
Aw, crap. My monitor had a small circuit board along one side which connected to the LCD panel with 3 very thin, very _fragile_ flat cables, which got ripped while I was peeling off the film. I should have reassembled most of the monitor before getting to this part, so I wasn't putting stress on the connections. Drats.
Good thing I was using a semi-busted old display.
Jan 25, 2012. 10:31 AMpranavsharma2504 says:
that must have been the inverter for the backlights
Nov 29, 2011. 10:38 PMautofire says:
My LCD screens film seems to have the matte finish and polarized film as one sheet, so its incredibly hazy, anything i can do to clear it up?
Dec 13, 2011. 8:05 AMhoff13 says:
You can just put the piece in between damp paper towels for about an hour or two and the matte finish will peel off quite easily. BTW, hot water worked better for me.
Dec 18, 2011. 7:20 PMPCChazter says:
I tried this, but the polarized film stuck to the matte finish, and a piece of clear plastic pealed off
Jan 17, 2012. 10:06 PMcomputer_guy says:
try 4 hours instead of 2, and dont go less than 4 hours. on top of that, try and go in a different direction from the polarization.
Jan 18, 2012. 1:23 PMcomputer_guy says:
as an added note, make sure you focus ONLY on removing the Anti-Glare film. when you're done removing it, LET IT DRY. Don't try to cut it. DONT use paper towels. They will stick to the polarization film. You might want to try a hair dryer, or if you want to play it safe, place the film on aluminum foil.
Jan 6, 2012. 5:52 PMMattrox says:
I wonder if this could be done on a cellphone?
Dec 25, 2011. 10:50 AMuldics says:
I actually had done this before we got internets in the end of 80ties. But just for my watch, didnt have LCD monitors back then. The polarising film was taken from screendead egg catching game: http://curiosityquills.com/wp-content/uploads/2011/06/elektronika_im02_nu_pogodi.jpg
And the only thing I could use it for was my Elektronika 5 watch.
Dec 19, 2011. 8:02 PMjx53 says:
I am curently making this on an old laptop that I've paid 50$ yesterday like I was suggesting and it work like a charm, Yon don't even need to cut anything. I just disasembled the screen and then scratch a corner until the filter lift up so I can pull it.
I'll post photos if you want when It will be done.
Dec 16, 2011. 1:26 AMMeister27 says:
Will it work with that? http://www.amazon.de/Brille-Hornbrille-Polarisationsbrille-Wayfarer-style/dp/B004QNER5Q/ref=sr_1_3?ie=UTF8&qid=1324027375&sr=8-3
Dec 17, 2011. 4:53 AMMeister27 says:
Okay thanks! Next question: Will that work? http://www.tradoria.de/optik-baukasten/polarisationsfolie-330189346.html
My LCD screens film seems to have the matte finish and polarized film as one sheet. I tried a lot but i cant get them off each other.
Dec 15, 2011. 7:09 PMjx53 says:
Very nice idea and result, it would be so insane to do that on a laptop screen and to use it in a public place =D haha! xD so my question is, will it work the exact same way on a laptop screen? I guess yess but I am asking to make sure it is.
Dec 15, 2011. 5:38 PMbeaver84 says:
Neat!
Dec 15, 2011. 3:58 AMElectorials says:
Really awesome!
Dec 13, 2011. 2:24 PMblinkyblinky says:
Cool...
Perfect for me.
Nov 24, 2011. 12:13 PMlemon rind says:
Would it be possible to make it so one pair see's one half of screen and another pair the other half? For split screen gaming :-)
Nov 25, 2011. 2:48 AMironsmiter says:
short answer... no
not with the hardware the author used.
You COULD do it with some more severe hacking.
You would need COMPLETE disassembly of the lcd.
Access to the rear polarizer would be required as well as the front. (see http://en.wikipedia.org/wiki/File:LCD_layers.svg for a super simple diagram of what goes where in an lcd)
Once both are off(Need to come off clean, and complete, cause you'll be using most of both of them). you start the cutting.
First, divide both filters EXACTLY in half.
Second, reassemble the lcd with 1/2 of each filter covering each side of the screen, in place of the rear polarizer.
Third, make two pair of glasses. One with the left over of each polarizer.
If you want to get super tricky, make a third pair of glasses, with one lens of each type. Now, you could display stereographic images onscreen, for your own Stereoscopy!
If the filters didn't come off cleanly(like my last lcd backlight repair... the filters were held against the screen by pressure from the assembled screen frame. Also makes you less likely to destroy your lcd screen with the exacto knife!)
then you still have options!
You can BUY polarizer films pretty cheaply from educational stores/science surplus/e-bay/amazon.
Once you have cleaned the glue residue off from removing the old filters... simply use the new film to do the modification.
FINALLY... If you DO get this to work.
WRITE AN IBLE!
and be kind enough to mention me in credits :-)
hmm. I wonder.
That old Pentium 2 era IBM laptop might just work.
Let the race to document and post begin!
Dec 11, 2011. 8:35 PMlemon rind says:
Wow, thats no easy task. Mabey I'll try your one before I go quite that far.
Nov 29, 2011. 1:54 PMUptonb says:
Congrats on being featured here!
Dec 11, 2011. 1:51 PMLight_Lab says:
Why you are so happy you have effectively made our idea useless? This is why I didn't publish it.
Nov 28, 2011. 12:38 AMXarxos says:
Any idea if this works with LED monitors as well?
Dec 10, 2011. 3:19 PMsethcim says:
(removed by author or community request)
Nov 28, 2011. 10:01 AMmcavano says:
LED monitors have the same LCD matrix, they just have a different back light system, which is of no consequence to this hack. Should work great!
Nov 29, 2011. 1:23 AMwwinquist says:
I have two questions, both of which deal with one problem: I wear prescription glasses. How well does this thing work if you try to use both your lenses and the polarized film? Also, would getting prescription 3D glasses work with this as well? (What about regular 3D glasses like you can get at Best Buy?)
Nov 29, 2011. 8:41 AMnflemming2004 says:
3d glasses for home tv's work using an LCD-shuttering technology (expensive, but works on home tv's), where the movies use a polarization technology (cheap, but only works for special projected displays), so the 3D glasses at best buy won't work. Then again, the 3D glasses at the movies won't work either, since they use "circular" polarized films, and for this hack you need "linear" polarized films...
Nov 29, 2011. 10:44 AMwwinquist says:
What about the prescription part? Would figuring out a way to apply it over the lens work or be worth it?
Dec 10, 2011. 1:19 PMlis.tesla says:
the best thing is to get regular polarized sunglasses
for mine the best angle is to slightly tilt my head to the left but still it's cool
Dec 9, 2011. 9:21 AMIrishpyro says:
Might I suggest trying to make a sort of clip on for your glasses? Like those shades you can get that attach to the front of your glasses. Am I making sense?
Dec 18, 2011. 6:06 PMjumpfroggy says:
This is the route I would go. Get a pair of those cheap $5-10 clipons from the store. Remove the lenses. Cut the polarizer into shape for each lens, drill holes, and re-mount to the clip. Then you can clip them to your glasses.
Another alternative is to use the "slide on" / "coverall" type sunglasses - the ones old people use over their glasses. They're basically oversized sunglasses made to fit over normal glasses, which is exactly what we want here. Pop out the lenses, replace with polarizers, and you should be set.
Nov 29, 2011. 11:12 AMnflemming2004 says:
If you can figure out a way to get the filter in front of your glasses (on the opposite side of the glasses as your eyeballs) it should work fine.
If you get prescription polarized sunglasses, they should work halfway, since polarized sunglasses are polarized horizontally, and almost all monitors are polarized 45 degrees from horizontal. The downside of this is that what you'll see is half the light from the image displayed, and half from the "blank screen" effect that everyone else sees, giving you a large reduction in contrast (but you should still be able to see it).
Dec 10, 2011. 8:19 AMsirbow2 says:
ive gotten the layer off of the lcd and it is completely white now, but the AG and polarizer are stuck together. how do i get the AG off of the polarized layer?
Dec 8, 2011. 9:23 PMzackthebuddha says:
This works with my old cell phone (HTC Dream/G1), but when I take off the last layer (completely clear), I can't see the image through the filter anymore! The screen is completely white with and without a polarizing filter on top of it. I haven't taken the one in the back out...but I don't understand what's going on! Any help? (note the photos are taken through a polarizing filter taken off an iPod mini)
Dec 3, 2011. 1:42 PMAndroid574 says:
Hey, I've tried to do this with an old LCD Monitor, but it's kinda weird. The first film is shiny on one side and dull on the other side, and behind this film the monitor gets really glossy. There's another film on it which is EXTREMELY hard to peel off so I gave up. I've connected the LCD with my computer and the part where the first film got removed was still black as it has to be, just glossy, were able to see my mouse-cursor and everything. The one small spot where I removed a bit of the "hard to peel of sh**" was shining white and ofc I didn't see anything like a cursor or whatever. Which film is this hard-to-peel-of-film? Is it the polarized one or the frosted anti-glare film? Because I really can't remove it.
1-40 of 256next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
91
Author:dimovi(CutYourWay.com)
I'm an electrical engineer interested in making stuff!
