Step 3Clean the film adhesive
With some solvent, soften the glue and wipe it off with paper towels.
I started with OOPS, but that was not fast enough so I got some paint thinner.
I found out that if you cover the screen with paper towels and then soak them in paint thinner you can let it sit longer and dissolve the adhesive without running and evaporating.
Scrape off the soft glue with a piece of plastic or wood.
Be careful not to get paint thinner on the plastic frame, because it will dissolve it.
If you use the hand sanitizers without scent or moisturizers, this gives you the benifits of rubbing alcohol while making it evaporate a bit slower.
I use it quite often for removing tape goo and have never had an issue.
Alternatively, lemon oil is great for removing adhesives, and safer to use than most solvents. Or, if you don't want to pay so much, WD40 is also a bit nicer to use than paint thinner - I'm asthmatic and find heavy solvents will sometimes trigger an attack.
You can always leave the adhesive on the glass if you don't care about how it looks.
Citrus oil will probably work too.
