Step 7Reassemble glasses and enjoy!
People might think you are crazy, staring at a blank white screen wearing sunglasses!
But I guess that makes it even more fun!
All Steps Viewing
for mine the best angle is to slightly tilt my head to the left but still it's cool
Another alternative is to use the "slide on" / "coverall" type sunglasses - the ones old people use over their glasses. They're basically oversized sunglasses made to fit over normal glasses, which is exactly what we want here. Pop out the lenses, replace with polarizers, and you should be set.
If you get prescription polarized sunglasses, they should work halfway, since polarized sunglasses are polarized horizontally, and almost all monitors are polarized 45 degrees from horizontal. The downside of this is that what you'll see is half the light from the image displayed, and half from the "blank screen" effect that everyone else sees, giving you a large reduction in contrast (but you should still be able to see it).
Just wondering if this can be adapted to work with prescription glasses?
so i tried this and everything works as per specification. what i did notice, however (and what the article neglected to mention), was that the polarization film makes the contents of the screen fuzzy -- especially the further you are away from the monitor. If you are more than 2 feet away from it, then just forget it. as cool as this project is, due to this limitation, it's really more unpractical than anything else.
the filter was made to function while pressed directly onto the glass. even moving the filer an inch away from the glass and you can already see a large degradation in picture quality.
http://www.instructables.com/image/FS9CRH1GV9CELUY/Monitor-done.jpg
notice how the upper left part of the film is clear, but the bottom right is hazy.
That's because I removed only half of the anti-glare film.
If you remove everything from the polarizing film it would be crystal clear. The movie above was recorded with the glasses 5 feet away from the monitor. If you can't clean your polarized film just buy some online. If you happen to have polarized sunglasses, you can try it by holding them far from the monitor at 45 degree angle.
I guess one would only need 3D glasses with each lens with the same polarization, right?
Now the perfect thing would be to find transparent polarized filters...!
http://en.wikipedia.org/wiki/Liquid_crystal_display
about half light is by default blocked by polarization filter, and other half is blocked by crystals (the ones which create image)
See this is why I hate being old we never had such cool things when I was a teenager :(
Cool idea though I think I will do it to scare my house mates into thinking I've lost the plot.
