Pro USB DMX Controller and Terminator for QLC+
2,968
28
8
Posted
Introduction: Pro USB DMX Controller and Terminator for QLC+
Today I want to share with you how to make a professional looking USB DMX controller to use with lighting control software such as QLC+. In roughly 5 to 10 minutes and about $35 in parts and shipping.
This project may actually take less time for you to compete than it takes for your soldering irons to heat up.
It only requires three parts. An FTDI USB-RS485-WE-1800-BT cable, A female XRL connector and a 13/64" x 1/4" piece of shrink tubing.
After you complete this project you will end up with a professional looking USB-DMX interface you can be proud to show off. If you complete the DMX terminator portion also; you will have everything you need to connect to any DMX enabled fixture or a whole DMX universe. You can also make and use more than one at a time to control multiple universes.
There are other tutorials that claim you can accomplish the same outcome for around $10. But this is not completely true. They fail to mention on top of purchasing the $10 board you need in addition: wire (?), panel mount connector ($6), a project box ($10) and shipping (shipping alone was around $30) for a total of about $65 not $10. Then the majority of the time the chips have to be hacked because the board manufacture changes chipsets or board design. In the end you end up with something pieced together and only works part of the time if you can even get it to work.
Im not claiming this project is cheaper depending on vendor and your location, shipping and tax may differ slightly. Im just saying this works, its clean, and parts can be purchased directly from the same manufacture and function as reliabley as a $150 name brand USB DMX controller.
Step 1: Make Sure We Have Everything We Need.
Parts and Tool list.
1) FTDI USB-RS485-WE-1800-BT cable
1) Female XRL connector
1) 13/64" x 1/4" piece of shrink tubing
1) Soldering iron.
1) Wire cutters
1) scissors
Other Links
Element 14 USB-RS485-WE-1800-BT
Element 14 XLR
Digi-Key USB-RS485-WE-1800-BT
Digi-Key XLR
Disclaimer: This is a do at your own risk. I hold no responsibility for burnt fingers, damaged equipment etc.
Step 2: Trim Red Wire
Do NOT cut the red wire all the way off.
We want to trim the red wire down to about 1/4".
Warning:
If you cut the red wire flush with jacket you will likely short it out on a cup when putting XLR together. Causing damage to your DMX fixtures and your computer.
Step 3: Terminate Data
We need to terminate Data+ and Data- with 120 ohm resister as per TIA-485 standards and FTDI spec sheet.
Lucky for us there's a 120 ohm terminating resister on the PCB 120R Pin 1 (Brown Wire) and 120R Pin 2 (Green Wire)
Basically we just need to know we need to twist the green and yellow together. Then twist brown and orange together.
Step 4: +5V Isolation
We need to fold the red wire back onto jacket & secure with a piece of shrink tubing, insuring that the tip of the red wire is completely covered by the shrink tubing.
By doing this we are preventing the USB +5 volts from shorting out. If the red wire is not properly isolated it could destroy your DMX fixtures and/ or computers USB.
Step 5: Install XLR Strain Relief Boot
Step 6: Prep Female XLR
We need to tin the cups on the back of the XLR.
Step 7: Prep Cable
We need to tin the wires to insure a good solder connection to the XLR cups.
Note: Ive had a couple people ask how I got shrink tube to stay on the alligator clips without splitting.... That is not shrink tube on the alligator clips, it the outer jacket of a piece of Cat5. Cat5 jacket works good to protect wires when clamped in alligator clips. Protecting wire jacket from being nicked by the alligators serrated jaws. And slides off easily when you need to clamp connectors or boards in your alligator clips.
Step 8: XLR Pin 3 (Orange and Brown)
We need to solder the orange and brown wires to pin 3 on the back of the female XLR connector.
Step 9: XLR Pin 1 (Black)
We need to solder the black wires to pin 1 on the back of the female XLR connector.
Step 10: XLR Pin 2 (Yellow and Green)
We need to solder the yellow and green wires to pin 2 on the back of the female XLR connector.
Step 11: Install XLR Strain Relief
Step 12: Assemble XLR
Step 13: Part 2 (DMX Terminator)
Step 14: 120 Ohm Resistor
Solder a 120 ohm resistor between pins 1 and 3 on the back of a male XLR connector.
Step 15: Disassemble XLR Boot
Using a small screwdriver or something similar. Push the strain relief tension ring out of the XLR boot. Then remove the boot from the collar/ nut.
Step 16: Trim Strain Relief Tension Ring
Trim off the portion of the ring that protrudes into the boot.
Step 17: Trim Strain Relief
Trim strain relief so it flush when tension ring is push down on the strain relief.
Step 18: Test Fit
Step 19: Cap the Back
take a thin piece of plastic and cut it the same size as tension ring.
I used a plastic business card. But the top off a gallon of milk works well also if you want to color code universe ends to aid in troubleshooting.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
8 Comments
Great instructable! I've been eyeballing making my own DMX to USB cable at the University I work at. This made me bite the bullet and buy the parts!
I do have to ask though, what's the DMX terminator for? I'm a carpenter getting into more electrical things and I have never heard of a terminator.
Terminator is installed at the end of the dmx line (last fixture). Kind of like a "Dummy load" if you will. What it does is prevent interference from entering the DMX communication line do to open connectors on fixture.
DMX will function without an end of line resistor/ terminator in most cases. But without it you may see intermittent issues such as lights flicker, delayed command responses, misinterpreted commands etc. This goes for all DMS systems. Not just when making this QLC usb dmx.
So the terminator is not necessarily vital it just creates a more robust system.
Cool, thanks for the info! I assumed it was something along those lines.
When I get a chance Ill add a video of it in use
cool, thank ya very muchly :)
hi there, came across this a few weeks back and it looks interesting :)
how would it compare to my velleman DMX kit ? =- it is sluggish as all hell -=
many thanks :D
Very nicely presented tutorial. Great photos, clear instructions! Thank you for sharing this.
