3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Lightbox for expose PCB
Ever want to make a uv lightbox to expose your PCB?
I gone explain how you make a handy and professional lightbox for less money.
Important!
UV light is bad for your health, avoid long exposure to UV light
UV-A lamps are best to use for your light box.
UV-B are the most harmful to your health, do not use these lamps.
UV-C: This lamps are too weak to expose your boards.
Step 1Materialen / Materials
  • last photo ←
Parts
- Two face tanner, total 8 UVA lamps (4 UVA lamps is more than enough, but if you want to illuminate printboard faster or larger 8 lamps much better )
- 15mm MDF
- digital Timer (with countdown function)
- swith on/off
- Glass ( glass from a picture frame) 40x30 cm
- + 5mm foam 56x32 cm
- Aluminum foil or mirror 30x30 cm
- Two-drawer slides
- piano hinge 40 cm
- Screws 3.5x35
- Wood Glue
- close contact glue
- plug
- electric wire
- 4 rubber legs
7 comments
Nov 28, 2011. 8:56 PMyussalfianyusof says:
Dear David,
May I know what's the technical specific of UAV lamp that you're using in your DIY.. and if not mind where did you get the UAV lamp...
thx and appreciated your reply
Jan 25, 2009. 4:45 AMPhil B says:
I appreciate this. Giving the text in both languages is helpful. I do not think the translation program got "expose your boards" right. In the Dutch text where 'boards' appears in the English translation, the original word is usually belichten, which I understand to be illuminate. It is the same in German as Dutch. But, boards are slabs of flat wood.
Jan 27, 2009. 12:35 AMwilnix says:
I think the right word is expose (belichten) instead of illuminate (verlichten). I think a Instructable shout be in English be course this is an English site. However I speak Dutch there are many language I don't understand. So keep the site only in English please.
Jan 25, 2009. 5:23 AMPhil B says:
David, I am not sure what English word to suggest because I was not certain of the meaning of the Dutch word "mee." Perhaps it is the same as the English word "me." Do not worry about your English. I have visited Germany and tried to communicate in German. Speaking (or writing) in another language is difficult.
Jan 25, 2009. 6:13 PMPhil B says:
I just looked at this again. I think you changed the title. Now the reference to 'board' makes sense.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:DavidRoman
