Problem Animal Snare Trap
17,450
25
22
Posted
Introduction: Problem Animal Snare Trap
This is a snare trap that i use for smaller game such as rabbits and birds.
Step 1: Items You Need
The items u need are very simple to get and are not very expensive if u already have a good knife\
1)Some kind of cord u can tie a good, strong knot into I used bank line (what people use to set bank poles)
2) a good sharp knife
3)somewhere to set your trap
Step 2: Tie the Loop
In this step u tie a loop to put back over the end of ur line
1st Picture: Just fold one end of ur line down to make a loop
2nd Picture: (Isn't very good) Take the loop and tie like u do for the first step in tieing ur shoes u know criss-cross. Pull tight
After u get ur loop tied put the other end of the string into the loop and u should have a snare
Step 3: Setup
Go to the place where the animals are causing the problem and tie the open end of the line to a strong anchor.
Next dig a hole (within reach of your snare) big enough and deep enough for your prey to get their head into.
Next bait the bottom of the hole
Next make your snare sit just on the inside of the hole.
Now wait check every 2 - 3 hours
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    24 Comments
    Blurry pictures, just saying
    great idea! tried it but cought nothing, any ideas? also what should i use for bait for squirles?
    I'd be really interested in knowing how to do this but I have no idea what is happening in this step. I get that I'm looping one end of the rope over and tying it. . . somehow like tying shoes. How does that make a trap? Am I making some kind of noose? More or much better pictures would be great and a more thorough description is needed here.
    I inherited a knife exactly like that one from my grandfather. Unfortunately the handle had become brittle and fall apart.
    looks like a ka-bar or a sheffield and the handle is made out of leather rings you could take it to a blade smith or a tack shop an have it repaired
    i also got the knife from my grandfather it is still going strong though
    My friend actually has that same knife and he inherited it from his mother.
    that rope is way too fat. the animal is going to be on to something
    haha ur right XD
    ... i've built tons of trap. for the best results, i'd use a figure 8 on a bight and feed the running end through. as far as digging a hole and leaving the rope in the hole doesnt seem very effective. animals are smart. with a snare, you'd need a load bearing mechanical advantage system. i prefer a black plastic 55 gallon drum on a pulley system. bending trees over is very unreliable and more difficult than running a garden hose up the tree. I had use nearly 400 feet of hose to our auxiliary wale. as far as the triggering system, you have to use an anchor. i use a 5' stick about 3" thick driven nearly all the way. as far as the triggering system, simply use a clovehitch to attach a pin between the working end and the load bearing end, near the anchor and wrap it around the anchor once. you can notice that you should be able hold the load by holding the pin in place with one finger if set up at the right angels and such. take a thin trigger pin (2' long stick) and run it to hold the load pin in place using another stick rammed in the ground. i use a long knife i paint hot pink to 'disarm' the pin from accidentally yanking off a finger. that is a basic crash course on catching uncle bill from finding your moon shine still.
