3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Prodigious Paper Rockets!
Step 2Making the rocket body...
Use the 3/4 inch PVC pipe as a form to create your rocket body. (Or the size of your launch tube if you modify the launcher construction.)
1. You have a few choices on rocket length.
a. Turn the card stock on its side (landscape) and roll it onto the PVC pipe. (pictured)
b. Turn the card stock straight up and down (portrait) and roll it onto the PVC pipe.
c. Longer rockets can be made by creatively joining tubes.
2. You want to keep the card stock as straight as you can on the PVC pipe and use a rolling pin
action to tighten the card stock onto the PVC pipe. You want some tension, but not too tight.
3. Once you are satisfied with the card stock tube, back off the roll about 1.5 inches.
4. Evenly spread a layer of white glue (Elmer's) along this section and roll it back into shape. Do not use too much glue because it will just squeeze out when you roll the tube again.
5. Set it aside to dry. When dry, it should slip off the PVC pipe with just a little tension.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:jdman
Retired this year
