3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Professional PCBs almost cheaper than making them at home
Step 10Create the Gerber files
This is the important bit. You need to click on each one of the tabs circled in green and ensure that Mirror (circled in yellow) is off. As you click through the tabs you will notice the Nr and Layer lines highlighted on the right will change. One default you might want to change is component values - in my copy this was deselected and the silk screen ended up with U20 but not the actual chip - eg an IC might be 74HC04. Click along the tabs to Silk Screen Cmp, and click on 27 tvalues. Once all the mirror boxes are definitely unchecked, click on Process Job (red circle).
1 comment
Apr 2, 2010. 7:36 PMabraxas2 says:
Thanks for taking me a leap forward. When I process this board into files via the CAM, I notice the check box "Fill Pads" is checked and I can't uncheck it because it's grayed out. Sure enough the artwork in the files generated has all of the pads filled in. I'm doing home brew boards so I need these holes as a guide for my drill. Your help in unfilling these holes is appreciated.
Dec 5, 2011. 3:53 AMsiddhc says:
Hi,
I also have the same problem .. "Fill pads" is checked and I cannot un-check it.
Please help if you figured out the solution.
Thank you very much,
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:Dr_Acula
