3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Professional water rocket guide
Step 7Now for the professional water rockets
Professional water rockets can vary from big one stage rockets to 2 stage rockets with drop away boosters.
This stage of the instructable will show you how to make a big one stager and how to couple or splice bottles together.
step 1 : coupling and splicing
How to couple bottles
first drill a hole about 7-8mm in width in the bottom of one of your bottles.
Next screw the male end of a plumbing coupling which is about 8mm in width into the bottom of the bottle, then seal it with a sealent glue. Next drill an 8mm hole in the other bottle cap and then insert the male end in to it. Whist the bottle cap is off the bottle, screw the female end into the other side of the bottle cap (side facing the inside) If you want you can seal it with glue as well.
4 comments
May 19, 2012. 10:45 AMChemdude118 says:
I use small sections of threaded lamp rod for my water rockets, but I don't know about oscarthompson.
May 22, 2011. 10:50 PMleiamme says:
What kind of plumbing coupling?
Jan 18, 2011. 5:16 PMfamos_amos says:
what with the picture?
Dec 4, 2009. 12:13 PMraynman217 says:
good so far, but the diagram for this step cannot be viewed properly at the current size, and even when viewed at the right size, it is very hard to understand.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
40
Author:oscarthompson
I like to make instructables which are fun to build or make. I'm instrested in rockets, Bikes science and Rowing. send me a message if you have any questions.
