Programing With Java Using Command Prompt
Published
Introduction: Programing With Java Using Command Prompt
This instructable will teach you how to:
1. Install the Java Development Kit.
2. Set system variables to easily be able to compile and execute java files.
3.  Compile and execute a Java file from Command Prompt.
** This is mainly for Windows 7 and Vista.
Step 1: Download Latest JDK
1.Follow this link: http://www.oracle.com/technetwork/java/javase/downloads/index.html
2. Click Download JDK under the download Java Standard Edition panel.
3. Choose your operating System and agree to the terms of service. **
** This will  probably be Windows since your using Command Prompt.
Step 2: Setting Path for Command Prompt
1. Open the Command Prompt .
2 Type "set Path=C:\Program Files\Java\jdk1.6.0_21\bin" .*
3. Type  " set HomePath= C:\Program Files\Java\ jdk1.6.0_21 *
* If you have a later jdk ( i.e. jdk 1.6.0_22) replace the portion that says jdk1.6.0_21 with it.
** If you don't know which jdk you have go to: start pane( at bottom left corner of you screen)>click run> click browse>Then  go to C:\Program Files\Java
*** Do not type quotation marks in steps 1-3  at command prompt.
Step 3: Creating a Simple Java Program
Create Program
1. Go to Start pane>All Programs > Accessories> Notepad.exe
2 Copy and paste the following exactly:
public class helloworld
public static void main(String[] args)
System.out.println("Hello World!");
3. a.Save file as: helloworld.java
     b.Make sure "save as type" under where you typed the file name as "All Files" (as opposed to the default "Text-File").
      c. You want to save your java file where  the Command Prompt  is set to open at.*
*Such as C:\Users\MyUserName
Step 4: Compiling and Executing the Program
1.First compile file by going to Command Prompt and typing javac  helloworld.java
2.This will create a class file which you can execute by typing java helloworld
3. It should print "Hello World!" to show your done.
Step 5: Learn More
1. The next thing you want to do is get a textbook that will teach you the Java language, precisely.I recommend Programing and Problem Solving with Java
 by Nell B. Dale and  Chip Weems .
2. You can get this from Amazon.com following this link:
http://www.amazon.com/Programming-Problem-Solving-Java-Weems/dp/0763734020/ref=sr_1_2?ie=UTF8&qid=1291909285&sr=8-2
  • Casting Contest
    Casting Contest
  • Woodworking Contest
    Woodworking Contest
  • Planter Challenge
    Planter Challenge
11 Comments
I have a problem with step 4, it just says " 'javac' is not recognized as an internal or external command, operable program or batch file
Same here......
Wonderful! I have been scouring the internet trying to figure this out without screwing stuff up. Thank you for making it so clear.
Hi, the tutorial has been really helpful, I have some questions, though:
1. Why do we have to type "set Path=C:\Program Files\Java\jdk1.6.0_21\bin" and "set Path=C:\Program Files\Java\jdk1.6.0_21\bin"? I tried just typing either one and it compiled just fine
2. Is there any difference between "set Path=C:\..." and "set PATH=%PATH%;C:\..." (besides the syntax)?
Thanks in advance :)
In cmd javac myprogramme.java,it takes few sec and there is no error but in cmd java myprogramme,there is a msg shown is-
Error:Could not find or load main class myprogramme
plz tell me how short out this prob??
Truely great................. Thats all i want to say
works 100%....
This works 100% fine. Thanx for adding it on net.
with these we have to take care of the spell and case of the class
