loading
NodeMCU Dev Board is based on widely explored esp8266 System on Chip from Expressif. It combined features of WIFI accesspoint and station + microcontroller and uses simple LUA based programming language. ESP8266 NodeMCU offers-
--Arduino-like hardware IO
--Event-driven API for network applicaitons
--10 GPIOs D0-D10, PWM functionality, IIC and SPI communicaiton, 1-Wire and ADC A0 etc. all in one board
--Wifi networking (can be uses as access point and/or station, host a webserver), connect to internet to fetch or upload data.
--excellent few $ system on board for Internet of Things (IoT) projects.
Recently, there has been interest in programming ESP8266 systems using Arduino IDE. Programming, of ESP8266 using Arduino IDE is not very straight forward, until it is properly configured. Especially because, the Input and output pins have different mapping on NodeMCU than those on actual ESP8266 chip.
I had request about showing how to program ESP-12E NodeMCU using Arduino IDE. I struggled myself earlier in the beginning, so thought of making this Instructable for beginners. This is quick guide/tutorial for getting started with Arduino and ESP8266 NodeMCU V2 ESP-12Ewifi module. (I think, this method can be used for other NodeMCU boards too. (or only ESP8266 boards, but with necessary hardware modifications and using FTDI modules for programming- not covered in this tutorial because, this is only for NodeMCU dev boards).
This Instructable gives quick intro to-
1) Installing Arduino core for ESP8266 WiFi chip in Arduino IDE and Getting started with sketches written using Latest stable Arduino IDE 1.6.7
2) Run/modify basic LED blink sketch to blink onboard LED and/or externally connected LED at pin D0 or GPIO-16 as per the pin configuration mentioned here and here.
NOTE- To use NodeMCU V1 or V2 or V3 dev boards using Arduino IDE, we do not need to flash it with firmware using nodemcu flasher. It is required only if we intend to program NodeMCU using Lua script with esplorer etc.
I have other video published on getting started with NodeMCU and flashing NodeMCU firmware on following link https://www.youtube.com/watch?v=x7GzK7zHKOk
**Arduino logo and NodeMCU logo are their respective trademarks- logos shown in above image were taken from -https://github.com/nodemcu and https://www.arduino.cc/en/Main/Software
Step 1: NodeMCU ESP-12E Pin Mapping
First and foremost word of - CAUTION !
* The ESP8266 chip requires 3.3V power supply voltage. It should not be powered with 5 volts like other arduino boards.
* NodeMCU ESP-12E dev board can be connected to 5Vusing micro USB connector or Vin pin available on board.
* The I/O pins of ESP8266 communicate or input/output max 3.3V only. i.e. the pins are NOT 5V tolerant inputs.
In case you have to interface with 5V I/O pins, you need to use level conversion system (either built yourself using resistor voltage divider or using ready to use level converters (e.g. these ones adafruit or aliexpress etc.).
The pin mapping of NodeMCU dev board are different from those of ESP8266 GPIOs. Attached images gives mapping of pins, source of images.
More information about pins is available on following links:
* Github - NodeMCU
* Github-esp8266/Arduino
Step 2: Installing Arduino Core for NodeMCU ESP-12E Using Arduino Boards Manager
As shown in the image, Copy the .json link with latest stable release of NodeMCU package from Github page here.
The link should look something like this-
http://arduino.esp8266.com/stable/package_esp8266com_index.json
Step 3: Insert Link for .json NodeMCU Package Files Into Arduino IDE
Paste the copied link and insert it in Arduino IDE using following sequence-
File menu - Preferences-
Paste copied link into the area shown in black box in above image. Close and restart the Arduino IDE.
Step 4: Tools - Boards Manager
Tools - Boards managerand search for ESP8266 and install the libraries/files given under heading ESP8266 by ESP community.
Restart the Arduino IDE once again.
Step 5: Selecting NodeMCU Board in Arduino IDE
Go to Tools - Boards (scroll down the list of boards) - Select NodeMCU 1.0 ( ESP-12EModule).
Select the Port number at which you have connected nodeMCU. Rest of the settings can be left to default values.
Step 6: LED Blink - Connections for External LED
We will be connecting external LED directly to GPIO16 or D0 pin of NodeMCU (no need of external current limiting resistor). This is the pin number for onboard LED or BUILTIN_LED (in my case it is blue LED - some boards might have green or red LED).
Step 7: LED Blink - Example Sketch
Go to File - Examples - ESP8266 - Blink
In my video, I have modified the sketch to blink LED faster, but you can leave as it is and just upload the sketch to ESP and there you go... the On-board LED blue and external LED red starts blinking alternately at every second.
Congratulations for successful configuration of Arduino IDE for ESP8266 NodeMCU dev boards.
Note- In case, if Arduino IDE version 1.6.7 fails to work for you, try to go back to arduino 1.6.5 or backwards. (I have heard, some NodeMCU boards have issues with latest versions of Arduino IDEs and going to earlier versions of Arduino IDE solves the problems).
Good luck for fun with this amazing system on board.....
Helpful links-
https://github.com/esp8266
https://github.com/esp8266/esp8266-wiki/wiki
http://nodemcu.com/index_en.html
https://nodemcu.readthedocs.org/en/dev/
My Doit NodeMcu Lua ESP8266 ESP-12E WIFI Development Board was from Banggood.com
ESP8266 ESP-12E CH340G WIFI Network Development Board Module For NodeMcu Lua ,, I have this board which i recently buy can i program it with arduino IDE and is it able to connect to blynk application ?
<p>Thank's for this short and complete introduction !</p>
<p>Works for me :)</p>
<p>I have problem send wrong direction. Also AT+GMR result is 2.2.89.2 and AT+RST result is error.</p>
<p>hello, please how can i do to generate a pwm signal with esp-12s using arduino IDE ?</p>
<p>Hey, can I use the PWM pin to dim a light bulb?</p>
yes you should be able to do that as far as i understand. but you need to check which pin no has pwm function and also modify code accordingly. <br>good luck
<p>Thanks alot for the response! :)</p>
<p>I need code for esp nodemcu to connect it with arduino on internet</p><p>plzzzzzz</p>
i haven't done that yet but will do soon.
<p>hi im using nodemcu v3(lolin) i installed ch340G driver but the device is connecting and disconnecting continuously plz help to solve this issue and what baud rate i need to use 9600 or 115200 , in board they mention 9600</p>
i had this issue mostly when i use bad or low quality usb cable. try changing cable.
<p>I have my breadboard used at the moment for a different project. But i was able to make the internal red LED blink with this same project.</p>
<p>Hello. <br>I didn't have any error, but nothing happened! I mean that the external LED didn't blink.......<br>What can I do?</p>
<p>Hello Jessteleco,</p><p>I have the same problem with both two boards which I have. Please, have you solved it finally? If yes, please, can you share the solution with me/us? Thanks</p>
<p>Can you go through it and let me know if it helped ?https://arduinonovice.wordpress.com/2017/01/09/how-to-use-nodemcu-module-having-esp826-with-arduino-software/</p>
just check if right pin no is selected in sketch and led is connected properly
<p>Try installing the driver listed on this page that matches your operating system.</p><p>https://www.silabs.com/products/mcu/Pages/USBtoUARTBridgeVCPDrivers.aspx#mac</p>
<p>Can the esp8266 only upload and download from websites or can I give it an IP address and port number to get info from a C++ app I wrote?</p>
<p>Of course. You can start from Examples -&gt; ESP8266WiFi -&gt; WiFiClient. That's simple base for TCP client/server. You might want to change the httpPort and printed string to something else.</p><p>Currently I have managed to build couple of LoLin temperature/CO measuring clients and RPi as a server.</p>
sounds interesting. ..i haven't tried hooking up to internet. if you manage to do that please share...
<p>is it IoT? </p>
<p>Great Tutorial. Thanks a lot. </p><p>As an additional comment, in my case the &quot;Blink example&quot; did not appear inside esp8266 library. But as tip for others, where the same happen, the sketch is the same as included in &quot;Examples/Basics/Blink&quot;. Only change the pin 13 for D0 or 16:</p><p>/**********************************************</p><p> Blink</p><p> Connected to pin D0 (GPIO16) ESP8266 NODEMCU</p><p> **********************************************/</p><p>void setup() </p><p>{</p><p> pinMode(D0, OUTPUT);</p><p>}</p><p>void loop() </p><p>{</p><p> digitalWrite(D0, HIGH); </p><p> delay(1000); </p><p> digitalWrite(D0, LOW); </p><p> delay(1000); </p><p>}</p>
thanks for sharing
the only way I can upload Arduino sketches with these boards is to press the reset and flash let simultaneously for a second and then let go of the reset key first, then it is able to upload the sketch.
that is weird because if you are using nodemcu it should work without any additional steps.
<p>good i'ble.Now after passing through everything ,</p><p>during uploading, i get this</p><p>warning: espcomm_sync failed</p><p>error: espcomm_open failed</p><p>error: espcomm_upload_mem failed.</p><p>what might be the reason , i am sure with the correctness of the serial port .</p>
<p>Hello dude i had the same problem, I solved by connecting gp0 and gp15 to ground, the before uploading the sketch disconnect and connect the usb thing</p><p>Tell me your results</p>
<p>I have the same exact problem and changing the baud rate didn't work.</p><p>Moreover, when I try to connect to the flasher program it doesn'find the board!<br>Anyone solved this?</p>
MatteoG2! Hello.!!<br>Install CH340G driver.Installing the driver solves ur prob.
<p>Hi Manoj! Thank you for answering! I just followed your suggest but still didn't worked. Actually because the chip mounted on my node MCU is the CP2102, and my PC actually recognize it on the serial port! <br>When compiling a sketch in the Arduino IDE, the antenna led blinks three times then the IDE tells me:</p><p>warning: espcomm_sync failed</p><p>error: espcomm_open failed</p><p>error: espcomm_upload_mem failed</p><p>error: espcomm_upload_mem failed</p>
<p>Hi Manoj. </p><p>I had the same error and the only way that my NODEMCU worked was setting up the speed to 115.200 and not 9.600 as specified at back of the board. Worked fine since after. </p>
<p>HI,</p><p>Very likely you have two (or more) Arduino-IDE/Serial monitor windows open.</p><p>Dave</p>
I remember having this error at some point but cannot recall correctly what I did to resolve it..<br>do you have anything connected to io pins of ur esp? especially D0 , if so just remove it for a while during programming. secondly, esp are power hungry devices... my esp shows errors when several sensors/peripherals are powered directly through nodemcu. just as a test, first try upload sketch on a bare board.<br>I hope this helps a bit. good luck
check your com port number and settings.
<p>if someone in the community could solve this,i would be grateful to them</p>
<p>Hi,</p><p> I have already setup and tested a weather iot using NodeMCU but now i need an external battery supply. My electronics knowledge is rudimentary at best but can i use a 9v snap jack cable connected to a jack to micro usb cable that is connected to the NodeMCU as a power supply? Will the ams1117 take care of the step down for the 3.3v or will that like totally fry my nodeMCU board? <br></p>
I believe it should work by applying 9v through usb socket..but not sure. you also need to be very careful that you do not apply 9v to usb data pins.<br>other way is to apply 9v via Vin pin of nodemcu. to the best of my knowledge the voltage regulator should take care of stepping down voltage to 3.3v.<br>just a word of caution. ..I have confusion whether max voltage can be 5 v or 12v at Vin pin..because I read in some forums that we can apply max 5 v only to Vin pin. but my guess is 9v at Vin pin should work.<br>good luck.
<p>Please, take caution with input voltages depending on your exact development board!</p><p>I have an ESP12E DEVKIT that has an CP2102 USB to serial TTL and voltage regulator that only accepts input voltages between 4 and 5.25v, so you will need (in that case) an 4.7 or (better) 5.1v zener diode, but remember that the difference will be dissipated by the limiting resistor.</p><p>Good luck!</p>
<p>Thanks Electromania! *Keeping fingers crossed *</p>
<p>I have the same error until I found some videos like this: <iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/XwHfKsz1xW4" width="500"></iframe></p><p>Some boards need flashing first with the tool presented on this video (my case with a no-name board), some don't (my case with an Amica board). After you've done the flashing procedure you'll be able to use Arduino IDE, putty, esp tools etc. Otherwise not. I use only Arduino IDE because I'm familiar with.</p>
<p>Hi i have error</p><p>esptool v0.4.9 - (c) 2014 Ch. Klippel &lt;ck@atelier-klippel.de&gt;</p><p>setting board to nodemcu</p><p>setting baudrate from 115200 to 115200</p><p>setting port from /dev/tty.usbserial to /dev/cu.wchusbserial1420</p><p>setting address from 0x00000000 to 0x00000000</p><p>espcomm_upload_file</p><p>espcomm_upload_mem</p><p>opening port /dev/cu.wchusbserial1420 at 115200</p><p>tcgetattr</p><p>tcsetattr</p><p>serial open</p><p>opening bootloader</p><p>resetting board</p><p>trying to connect</p><p>espcomm_send_command: sending command header</p><p>espcomm_send_command: sending command payload</p><p>trying to connect</p><p>espcomm_send_command: sending command header</p><p>espcomm_send_command: sending command payload</p><p>serialport_receive_C0: C4 instead of C0</p><p>trying to connect</p><p>espcomm_send_command: sending command header</p><p>espcomm_send_command: sending command payload</p><p>serialport_receive_C0: C4 instead of C0</p><p>resetting board</p><p>trying to connect</p><p>espcomm_send_command: sending command header</p><p>espcomm_send_command: sending command payload</p><p>trying to connect</p><p>espcomm_send_command: sending command header</p><p>espcomm_send_command: sending command payload</p><p>serialport_receive_C0: C4 instead of C0</p><p>trying to connect</p><p>espcomm_send_command: sending command header</p><p>espcomm_send_command: sending command payload</p><p>serialport_receive_C0: C4 instead of C0</p><p>resetting board</p><p>trying to connect</p><p>espcomm_send_command: sending command header</p><p>espcomm_send_command: sending command payload</p><p>trying to connect</p><p>espcomm_send_command: sending command header</p><p>espcomm_send_command: sending command payload</p><p>serialport_receive_C0: C4 instead of C0</p><p>trying to connect</p><p>espcomm_send_command: sending command header</p><p>espcomm_send_command: sending command payload</p><p>serialport_receive_C0: C4 instead of C0</p><p>warning: espcomm_sync failed</p><p>error: espcomm_open failed</p><p>error: espcomm_upload_mem failed</p>
never heard or experienced such errors. not sure what might be causing this. but just quick guess is...have you selected correct nodemcu board in boards manager?<br>have you installed esp8266 arduino core libraries properly?<br>is your usb cable good?<br>lastly do not connect it to usb hub.<br>good luck.
HI <br>have you installed esp8266 arduino core libraries properly? yes i installed libraries.<br>is your usb cable good?- good<br>thanks
esp communication error is mostly encountered by me when usb cable is not good, esp is connected to usb hub, improper driver, wrong board selected while selecting board in arduino ide. <br>check if you can see usb device in Windows device manager, try to change baud rate of your usb port, use short usb cable , do not connect via usb hub.<br>last option would be, try first to program usin esptool or lua loader, if it doesn't work even there then probably something is wrong in your hardware or in communication port. <br>I have a video on my youtube channel about getting started with nodemcu using esptool.<br>good luck
<p>Why is a current-limiting resistor not needed for the LED? The GPIOs are rated for 12mA and typical LEDs draw 20mA.</p>
<p>Looking at the schematic, you NEED a resistor, tho one onboard is only connected to the onboard LED.</p>
no, you do not need to do anything with Rst or Flash buttons, to program.
it is not required for D0 pin since there is an onboard resistor, as far as I know.<br>for other pins we will need a resistor.
About This Instructable
305,509views
334favorites
License:
Bio: A Researcher, an Engineer and an electronics enthusiast
More by TheElectromania:Quick Digital thermometer using cheap USB to TTL converter and  DS18B20 - WITHOUT Arduino or Raspberry Pi Digital thermometer on OLED display using ESP8266 ESP-12E NodeMCU and DS18B20 temperature sensor PIR Motion Detector With Arduino: Operated at Lowest Power Consumption Mode
Add instructable to:
