Programming MSP430-F2012 UC With Launchpad SBW
Published
Introduction: Programming MSP430-F2012 UC With Launchpad SBW
About: Texas Instruments; Launchpads; Arduino; Electronics; Climbing
MSP430F2012 is a clever 16 MHz low cost microcontroller from Texas Instruments with 10 GPIO (General Purpose Input Output), Analog Digital Converter (DAC), I2C, PSI,  Datasheet .
You can use it to drive servos, stepeprs, motors, leds, piezzo, midi, keyboard input and so on.
NOW it is very easy to program a MSP430F2012 with 10$ MSP430Launchpad from Texas Instruments and freeware Energia.
Step 1: What Do You Need?
A MSP430F2012 uC -> sample from Texas Instruments, or buy from Digikey 2.37$
OR A BOARD EZ430-T2012 - MSP430 F2012 Board 3 pieces for 15$
A MSP430 Launchpad -> from TI stroe 10$
Soldering station
4 wires
Download Energia IDE software from http://energia.nu/download/
Mac OS X, Windows, Linux
Step 2: Soldering the Wires
The Launchpad Spy-Bi-Wire interface hasn't a standard pin header. That is a half step header. I soldered 4 wires to the interface:
Launchpad                            F2012 board
o
o------------------------------------o
o
I used more Flux not to have a short on pins. Use a multimeter to verify Your work!!!
Step 3: Start Energia an Upload Blink Example
Energia is an ARDUINO like IDE for MSP430 Launchpad microcontrollers. It became popular because it is very easy to use, it has a lot of examples. It works on Mac, Win an Linux. You can program an MSP430 as easy as an Arduino.
It can be download for free from http://energia.nu/
After You have installed the Energia IDE.
1. Attach the MSP430F2012 to the Launchpad SBW interface.
2. Remove the RST jumper of the Launchpad
3. Start the ENERGIA
4. Open -> FILE -> EXAMPLES -> BASICS -> BLINK
5. Upload
Upload BLink example:
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
void setup() {
  // initialize the digital pin as an output.
  // Pin 14 has an LED connected on most Arduino boards:
  pinMode(RED_LED, OUTPUT);
void loop() {
  digitalWrite(RED_LED, HIGH);   // set the LED on
  delay(1000);              // wait for a second
  digitalWrite(RED_LED, LOW);    // set the LED off
Step 4: Be Happy
Running Your first programs on an F2012.
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    4 Comments
    above project nice......
    To connect the LDR to msp430g2553 .i am trying to program but ADC program are give error, so give code for LDR
    HI, I am trying to program this chip using the launchpad and Energia, but, since energia doesn't have it in the boards section, it gives me an error, how can I add it, or program it without selecting it?
    Thanks
    Hi Emiliano !
    Select Tools ->Board -> msp430g2231
    Upload the code. It will work :)
    Balint
    Some infos: What devices can be programmed with the MSP-EZ430U debugging interface?
    MSP430F200x, 'F201x, 'G2x01, 'G2x11, 'G2x21, and 'G2x31'
    http://www.ti.com/lit/ug/slau176d/slau176d.pdf
    Screenshot from 2014-05-27 12:25:16.png
    Hi Emiliano !
    Balint
