Introduction: Project X Knex Rifle V2.
After a few weeks of moding and improving my original project x knex rifle i have finally finished with verstion 2. The version still uses the same concept of removable parts but ads a better barrle, a scope and a kind of stronger stock. It now shoots about 30 feet when you make the v2. It is about as accurate as every other knex gun on the site.
After the v2 is put togerther there are pics for the v3 mod. The v3 is yet better and improves on the firing pin, the barrle, and the mag pusher. The v3 shoots about 45 feet. Any ideas for improving to v4 i would love to hear them.
The pros and cons of the v3
Pro
Removable options.
Shoots a good distance
It is pretty strong
Inventive way of makeing removable options
Kind of feels comfortable depending on how big you are
Cons
It takes alot of parts
It is flimsy in some spots
Some parts need to be cut
Crappy trigger system
Step 1: Building the Stock (Optinal)
1 the orgiginal pic
2 make 3 of these
3 layor all 3 and add white rods
4 make these
5 add blue rods where shown
6 add parts from step 4 to blue rods
7 add gears for support
Step 2: Build Bipod (Optinal)
1 Origninal pic
2 Make the_burrito_masters bipod from his park 52 rifle
3 Make 3 of these
4 Layor together and add blue and white rod
5 connect the 2 together
Step 3: Mag and Mag Pusher
1 Original pic
2 make 2 of these
3 make these 3 parts
4 Add cut rods where shown
5 Add orange rods over cut rods
6 add other cover plate
7 Add 3 white rods where shown
8 Add other orange rod like in pic
9 Make pusher (on the v3 the pussher has a blue rod instead of the white rod on the bottom part and a single grey where the top orange is) More pics will be shown later
Step 4: Scope (Optinal)
1 Orignal Pic
2 Make frame
3 Make the sight part
4 Another view
5 Another view
6 put together
Step 5: Second Handle (Optinal)
1 Origninal pic
2 Make 3 of theses
3 Layor the three together and add 2 white rods
4 Make this part
5 Connect green part to handle with white rod
Step 6: Stock Reciver
1 Original Pic
2 Make this
3 Make this
4 Make this
5 Make this
6 Make this
7 Add oranges
8 Add cover, single greys, and stock stopper
Step 7: Primary Handle
1 Orignal pic
2 Make these
3 Make this
4 Make this (know that there are 3 layors to this part but they are all the same)
5 Make this(know that there are 3 layors to this part but they are all the same)
6 Add part from pic 4
7 Add part from pic 5
8 Add part from pic 3
9 Add other cover plate and done
Step 8: Trigger Gaurd
1 Origninal Pic
2 Make these 3
3 Add yellow rods to first part
4 Add second layor
5 Add third layor over second and first layor
6 Add blue spacers
Step 9: Upper Reciver
1 Origninal pic
2 Make this (this is only one layor thick)
3 Make 2 of these
4 Make these parts
5 Layor the parts from pic 4
6 All three parts should be layored from pic 4 There should also be a spot down the middle for the scope
7 Add the layored parts to the part from pic 3
8 Add the other side to part 7
9 Add pic 2 to Either side. Placement doesnt matter it where you place it just determanis where the scope will be put and how far back or forward it will go.
Step 10: Firing Pin
This is the firing pin for the v2 the v3 pin will be at the end
1 Origninal pic
2 Make these
3 Make this
4 another view
5 Make this
6 Make this
7 Connect pic 5 to 6
8 Add yellow connectors
9 Add cut white
10 Add firing pin to part 9
11 Make this
12 Another view
13 Add firing pin
14 Add parts from pic 2
Step 11: Barrle
1 Original pic
2 Make this
3 Make this
4 Make this (To mod the barrle to the v3 barrle take out the tan clips for this pic and add orange connectors cut in half)
5 Add part from pic 3
6 Add part from pic 2
Step 12: Second Reciver
1 Orgininal Pic
2 Make 2 of these
3 Make this
4 Another view of pic 3
5 Add part from pic 3 to pic 2
6 Add other side
7 Add blue rod
8 Add orange connector
Step 13: Mag Holder
1 ORiginal and make 2 of the panles
2 Add 3 greens in the front
3 Add Yellow rod in the back
Step 14: Front Fake Barrle
1 Original Pic
2 Make this
3 Make this
4 Make these (There are 3 layors)
5 Make these (There are 3 layors)
6 Make these
7 Add Parts 4 5 6 to pic 3
8 Add cover plate
Step 15: Trigger Assembly and Lower Rail
1 Original Pic
2 Original pic another view
3 trigger system
5 make this
6 make this
7 make this
8 make this
9 Add pic 8 and 6 to pic 5
10 make this
11 make this
12 Add pic 10
13 front view of pic 12
14 back view of pic 12
15 add pic 11 to pic 15
16 Add pic 15 to pic 16
17 Make pic 17
Step 16: Putting It Together
1 connect the handle to the stock reciver
4 connect the firing pin to the handle and the stock recver
6 connect the trigger gaurd to the trigger assembly
8 Add grey connectors to the back of the trigger gaurd
9 add the trigger to handle
11 add the mag holder
12 add the barrle
13 Connect the fake barrle to the second reciver
15 connect the upper reciver to the handle and the stock reciver.
16 add the rest of the front the gun
17 connect the trigger
Step 17: V3 Firing Pin
1 new firing pin
3 where the rubber bands attach.
Step 18: Finished
this is the gun that is finished. go to step 17 for help on how to attach rubber bands. Also To make the trigger work you need to put a rubber band around the bottom of the long orange rod that you made and put that into the slot. Then pull it down and your ready. If you have any questions ask.
