Real Pipboy / IronMan : Wearable Heater + Runner Utility Light
Introduction: Real Pipboy / IronMan : Wearable Heater + Runner Utility Light
Background :
The Creation of Man by Prometheus (by J.M. Hunt) : "Prometheus had assigned Epimetheus the task of giving the creatures of the earth their various qualities, such as swiftness, cunning, strength, fur, and wings. Unfortunately, by the time he got to man Epimetheus had given all the good qualities out and there were none left for man. So Prometheus decided to make man stand upright as the gods did and to give him fire. "
Step 1: Real Pipboy : Wearable Body Heater + Night Running Utility Light "Prometheus" [ With User Interface + Rechargable ]
Problem Tackled :
And so, with the ensuing cold, the problem of athletes being cold on the run , and people in general being cold in overly air conditioned buildings, I invented Prometheus - an open source wearable heater.
DISCLAIMER + Final Words :
There is a wearable heater by the name of "Wristify" but it heats via a peltier element, relying on the psychological mishap and trickery of the wearer in order to work. Prometheus is actual warmth and as such if you decide to create this project, know that it is by your own discretion and that I am not liable for any injury.
Step 2: Video Overview + Minimum Electrical Diagram
Main functions and how the thing works + simple electrical diagram!
* To clarify Temperature Set Point :
Upper Value after " Heat On " Is what temperature the heater comes on at.
So in the video I kept increasing the value at which the heater would turn on. The moment the sensor value becomes LESS then the set point value [ or set point value becomes GREATER then the temperature sensor value ] then the heater will engage.
See : " // HEATING ELEMENT Routine" for more details in code below
See image above of how to make a simple volt meter using a voltage divider , reading voltage into an analog pin
Excel Sheet : Includes Full Running List Of 3D Model Updates For Band + Cover
ipt = inventor parts for editing
stl = 3D print ready files [ units = mm ]
*Print with PLA since tolerances are minimal [ although present ]
* Drill Hole For Laser Pointer instead of 3D printing
  • Wearable Heater Via Nichrome 22 Gauge Wire
  • For running at night :
Utility Light : 1 Watt L.E.D.
B-Seen Blue L.E.D.s
Laser With Diffraction Grate [ to definitely be seen ]
  • OLED Display
To See Set Point Value for heater
To See Battery Power
To See if unit is working properly
The Lights Automatically turn on at night [ via the photoresistor ]
Step 5: 3D Print Cover + Band [ 2 Main Parts ]
If you cannot open up the inventor parts
Or you just want to 3D print the damn thing , here are the parts
Step 6: 3D Model Parts
NOTE : The "cover " and "band" do NOT have room for a 3.7 V Lipo - The lipo battery is worn on a fake leather bracelet not yet shown [ look for video soon ].
Software : Autodesk Inventor Professional --- > Free 3 Year Trial By Signing Up
3D Printable Parts :
ONLY PARTS NEED TO BE Exported as stl and 3D PRINTED
  • prometheus_cover_V1.0_sd.ipt
  • prometheus_band_V1.0_sd.ipt
Other Parts = How Things Come together if you choose this model that has the laser pointer & screen
References : There are a few parts I found on grabcad that will be referenced in the official write up
these include : the transistor [ acting as the TMP 36 sensor ] and the pcb board , among others.
Re-Sizable :
With "Prometheus_band_V1.0_sd" Open in autodesk inventor professional, just change the sketch " Main Ring" under "Extrusion 1" to adjust the size for your wrist.
Note : Other features may change as a result - I have average sized wrists.
Trouble Shooting :
Problem : Assembly Not Complete or cannot find the files
Solution : Once you download Autodesk Inventor Professional , Download all the parts into 1 folder. Then when prompted for parts, simply search that folder to upload into the assembly
Step 7: Heat Calculation
  • The heating element used was nichrome wire.
  • Although dangerous if the length is not properly measured, the nichrome wire provides some of the best heat conversion from electrical power [ ie the battery ]. It does this using the inherent resistance of wire [ in the same way toasters work ].
  • A peltier element would work , but not nearly as well.
    • Much like goose bumps, a peltier element could be pulsed to create fluxes of warmth [ or cold ].
  • There are other heating elements, such as ceramics, but they tend to be too expensive and often require voltages higher then most smaller lipos [ usually 5 - 12 volts ].
For these reasons above, the nichrome wire was used.
READ! --- DISCLAIMER : Nichrome wire can get red hot if you do not properly calculate the wire length. As such, it is at your discretion when creating this project. I will post a video to demonstrate the safe setup, with the battery chosen, and how to safely test the nichrome wire.
The picture from the "Nichrome Wire Application Calculator " provides relativity warm and safe output for batteries at or above 2000 mAh. * Your battery needs to be able to provide this amount else it will overheat.
Nichrome Wire Application Calculator Website Used :
Step 8: Electrical Schematic [ Full Functions ]
I will go over the main portion [ heating part ] in a youtube video.
See "Features" to understand the other elements of the circuit
See Above For Simplified Electrical Circuit
Step 9: Electrical Parts
THE CHARGER + Battery Are located Underneath the Assembly on a separate fake leather band
*DANGER : Discharging the lipo battery below 3.4 Volts is Dangerous - which is why there is an oled display
  • Lipo Battery Charger : here -- > "a free bonus JST cable!" so your battery does not need a jst plug
  • 3.7 V , 2500 mAh Lipo Battery: here
Step 10: CODE
MAIN CODE : Prometheus_V1.0_sd
Main Libraries Used :
Other Tabs / Codes are for references and other oled displays
This code is quite involved but I'm still offering it for free.
Look for an authentic IRON MAN technologies Kickstarter soon!
Email me : for more details about how you can help make IRON MAN a reality
Or take this quick IRON MAN Survey! :
Step 11: FINAL WORDS - Please Read
I'd love to see what you guys do with this.
It may not be much, but I hope it changes the perspective we have of technology, if only a little.
I will upload another version without the laser pointer and with the charger built into the 3D printed cover & band if enough demand is present. Let me know in the comments
Want to help make IRON MAN a reality ? Want to learn how to make IRON MAN?
Support me at my Patreon at :
Any technologies attempted from my tutorials are at the discretion of the maker. You take full responsibility for any damages caused to property , self, or others while attempting my tutorials. Thank you!
Instead of reaching for technology, why don't we wear it?
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    "There is a wearable heater by the name of "Wristify" but it heats via a peltier element, relying on the psychological mishap and trickery of the wearer in order to work. Prometheus is actual warmth"
    Do you believe that Peltier devices do not work?
    It most certainty works , to a point and application.
    The forced sensation of warmth [ and cold ] induced by a peltier element only goes so far.
    As far as I can tell, the Wristify device induces shivers [ or goosebumps ] at a rate of about 12 pulses per minute [ based on personal testing].
    And although the Wristify device is like touching a hot or cold object against the body where the body is sensitive to this stimuli, I wanted to create a device that , if you were stranded on a cold night , you'd want this in order to de-thaw your fingers.
    Simply put, it's more practical [ especially for athletes who get cold fingers when running].
    And the thought of giving another approach to the problem and giving it for free is very satisfying.
