Here is an obfuscated ultraminimalized Monolith for you.
It is enlightening and harmless, except to the devil, who really hates it, because I'm letting you have it (for "free").
You're curious. So Make it, if you have tools.
Remove these ads by
Signing UpStep 1GET PARTS
You need:
-a PIC12C508 or 509 or anything compatible or be able to translate to what you have.
-an assembler and burner for your PIC
-a 78L05 voltage regulator which looks like a small transistor
-a dead 9 volt battery to rip the plus and minus terminals out of
-a new alkaline 9 volts battery
-some 20-ish gauge wire...
-a really stupid antenna which may be made out of the wire and hangers and aluminum foil,
so pretend to pretend you don't know a thing about making an antenna and make something that looks like one.
-A shortwave radio. A guitar amp will also be interesting, but definitely find the radio first.
-The CODE i am giving you to put in the PIC.
sorry this was too easy to make so I show the parts all together. You don't need the blue ship light.
If you don't have the right PIC, recoding just involves choosing different registers and a different port.
In the beginning was the Word, and the Word was with God, and the Word was God
please don't change the subject to religion but I find it an interesting resonance
perhaps the lost arc might have similar properties?
AM i correct in assuming that you have created a type of program that works in a type of repeating sequence into infinity and would or could eventually play every piece of music ever written or ever capable of bieng written?
http://www.instructables.com/id/How-Astronauts-will-Travel-To-Mars/
No-program Logic chip equivalent circuit.
Pandora's Music Box #2
The only existing similar or relevant science reference that I'm aware of is:
A NEW KIND OF SCIENCE
The author independently decided to use it to make music out of nothing.
This instructable is about making a simple version of my music maker.
more info:
Val Smith predicts Wolfram Tones
The All-Music-Set Player
The anomalies associated with this instructable is that since it is
generating endless "musical sound" using both sharp monopolar pulses
and a fractal as it's data source, the RFI field of the chip has a number of
dimensions which is a fraction.
For something similarly interesting, look at calcul8.txt and follow the
instructions in my Comments on this instructable:
How to get free music: see calculator comment
A similar number is already wrapped in a wav on the All Music Set page.
FREE:The Sum Of All Human Knowledge
