3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Prometheus/Pandora's Box
Prometheus/Pandora\
Some of you monkeys out there think you can PWN me. You need to be Spanked.
Here is an obfuscated ultraminimalized Monolith for you.
It is enlightening and harmless, except to the devil, who really hates it, because I'm letting you have it (for "free").
You're curious. So Make it, if you have tools.
Step 1GET PARTS
GET PARTS
This is easy.
You need:
-a PIC12C508 or 509 or anything compatible or be able to translate to what you have.
-an assembler and burner for your PIC
-a 78L05 voltage regulator which looks like a small transistor
-a dead 9 volt battery to rip the plus and minus terminals out of
-a new alkaline 9 volts battery
-some 20-ish gauge wire...
-a really stupid antenna which may be made out of the wire and hangers and aluminum foil,
so pretend to pretend you don't know a thing about making an antenna and make something that looks like one.
-A shortwave radio. A guitar amp will also be interesting, but definitely find the radio first.
-The CODE i am giving you to put in the PIC.
sorry this was too easy to make so I show the parts all together. You don't need the blue ship light.
If you don't have the right PIC, recoding just involves choosing different registers and a different port.
63 comments
1-40 of 63next »
Jan 6, 2012. 11:45 AMDramBuoy says:
Please don't shoot me but I have to say, making an analogue regarding the sum of all sounds/knowledge/effects. The start of a book which no one understands which has done more for war than hate begins this way.
In the beginning was the Word, and the Word was with God, and the Word was God
please don't change the subject to religion but I find it an interesting resonance
perhaps the lost arc might have similar properties?
May 6, 2008. 9:05 PMdaemonzx66 says:
nevermind that. I got it working. I hooked it up to a real antenna. I have never been more mystified by anything so simple. It seems like after a certain number of times through the loop that parts of the pattern get "flattened" and its almost like the pattern starts to fall apart for a split second but then it starts up again with a different order of notes. I can only compare this effect to the act of muting strings on a guitar while playing. Is there any notable difference in the output when using an external oscillator? I was just wondering because it seems like the chip's internal osc is limited in its range and I also wonder if that is what causes the flattening or if that is just part of the design. I am very grateful that you shared this instructable as otherwise I never would have known such things were possible.
Oct 7, 2010. 2:25 AMafridave says:
gooday excuse my ignorance but i found this and the links very interesting even though i have no idea what this thing is or what it does and have no intention or tools or ability to attempt to build it.
AM i correct in assuming that you have created a type of program that works in a type of repeating sequence into infinity and would or could eventually play every piece of music ever written or ever capable of bieng written?
May 7, 2008. 2:31 PMdaemonzx66 says:
Yes, by flatness I meant to say out of tune. I had a feeling that it was just a part of the pattern but I wasn't sure. The very fact that a device like this exists, or that it even CAN exist, makes my head spin just to think about. The pattern gets progressively more complex as it goes along, but am I right in thinking that it almost ebbs and flows? It reaches a certain level of complexity and produces a "verse" of polyrhythmic tones in a quite complex form and then will produce another "verse" that is almost "typical" and doesn't stand out, much like some of the early tone combinations. However, it then builds up again, almost like a microcosm of the whole process. But regardless of that, it just keeps chugging along relentlessly, becoming more complicated, as if trying to communicate a message of overall evolution but short term regression along the way. It's funny how the term "intergalacic radio" seems to fit so well. Listening to the sounds, I often imagine that this is some sort of radio broadcast originating from the beginning of time and that it has always been running. Every time I listen to it for an extended period of time it makes me feel like I have always been listening to it and that such a pattern constructing itself is "completely natural." It is also one of those tunes that gets stuck in your head, and I find myself continuing to imagine the sounds it produces even after its been turned off. This isn't bad in any way, actually its almost reassuring, but its just something I thought noteworthy.
Sep 22, 2010. 11:26 AMShadow13! says:
I don't know if this is possible but if it is someone should make this and hook it up to a computer and create a website so that even people who don't understand or have the material to make this could stream it over the web.
Mar 6, 2010. 4:54 PMLkArio says:
Samples hear?
Jul 23, 2009. 8:48 PMNicepolicy16 says:
Is there a Monolith on Mars ? Take a look at this Instructable :
http://www.instructables.com/id/How-Astronauts-will-Travel-To-Mars/
Jul 23, 2009. 9:25 PMNicepolicy16 says:
Apes and Monkeys will be the First to reach Mars, but not able to get home .
Jun 5, 2009. 10:34 PMtravace says:
seems to me that this is a big technological project design for a formidable mind. i however fail to comprehend your technological speak and have forgo this project to someone more capable then i. never the less i applauded your machine and you for designing it. i am an expert on the human mind and its comprehension. you my friend are a very intelligent individual and have surpassed most of my colleagues in your thinking. my hat is off to you my friend!
Mar 16, 2009. 4:01 PMPwag says:
My head hurts, wtf is this and why did it come up in a search for guitar amp?
Mar 13, 2009. 5:00 PMDeeder says:
Perhaps you should use the device while on acid to better comprehend it
Jan 3, 2009. 1:15 PMsocrateez says:
I don't have the materials to build this, but i briefly scanned your sites. Very interesting science. Could one in theory recreate or create Genome sequences then? Is this the equivalent of a room full of monkeys attempting to pound out Shakespeare's works on typewriters? Only you've found a minimum number of monkeys required to do so?
Feb 21, 2009. 9:19 PMFather Christmas says:
"...a room full of monkeys attempting to pound out Shakespeare's works on typewriters?" You must have been in one of my classes to say that.
Aug 12, 2008. 1:32 AMYerboogieman says:
is there a way to add a a microphone or anything?
Jul 22, 2008. 8:33 PMScubaSteve says:
I have a 50 foot TV areal bt my house. if i hooked it up to that it would be AWESOME!
May 7, 2008. 5:28 AMFleder says:
can anyone please tell me something what the hell is this thing
Apr 28, 2008. 2:55 PMdaemonzx66 says:
well, this does seem like a very interesting device indeed. I've gathered up all the parts needed to make it, although this is my first time using any PIC to speak of. I'm a little confused as to compatibility between certain burners and certain assemblers. Also wondering if I will need a compiler as well or if that's even different from an assembler. I have looked around and there seems to be vast amounts of information on the subject of PIC programming, so much that its hard to process all at once. I have a MCU programmer that's supposed to be 12Cxxx compatible but have not been able to get it working with any freeware PIC assemblers that I've found. Any help would be great, as I would love to find out the capabilities of this thing. (note: this may make a difference or may not, but the burner has a 6-pin rj-11 jack and i'm attempting to access it through a serial adapter)
Dec 15, 2007. 10:35 PMDaax says:
A few questions: (1) Does the tempo ever change? (2)If such a device were used to posses "the sum of all sounds", how in the world would it ever be efficient to "dial in" or access known music, as discussed elsewhere? Even if one created a divice that would take a song and find it within such an endless source of sound, would it ever be better than analogue? I mean it's all still digital right? The technology is not my field, but the concept is intrigueing. I am, however, still skeptical.
Dec 17, 2007. 10:51 AMDaax says:
Ok. So it could never play anything rubato. Nor could it play anything with set tempo changes within the song. Is that right? Is it safe to say that in its eternal cycle, one would never hear a song with minor tempo imperfections and some really hip feedback at the beginning? Please tell me if I'm wrong. If I understand (the result is the only thing I really get, I think), this thing would eventually play something that sounded like Row Row Row Your Boat played on a MIDI board if you waited long enough. However, one could also just locate where it would play the song by locating it within the function (via the methods you mentioned that are beyond my understanding in this field)? But no Pay to C*m by Bad Brains at this point (Or might there be?). Still seems inefficient for such use. It feels like carving a house out of a giant block of wood (locating the house's shape within the wood first), instead of just building it. No matter what, I say you should sell the device to Radiohead to use on one of their albums. The thing sounds awesome.
Dec 20, 2007. 12:35 AMDaax says:
That's pretty cool. I figured (and hoped) that such were the case. After all, thats what infinate things do (produce all possibilites). Infinate sound is the concept, and the only limitation is the physical aspect (right?). As for the houses: good point. Bad analogy on my part I guess.
Dec 15, 2007. 10:39 PMDaax says:
*still skeptical as to the hopefulness of using it in such a way, that is. Sounds beautiful though.
Dec 5, 2007. 2:47 PMrandom squigles says:
So if one wiped off all finger prints and tied it to several large helium balloons with a long magnet wire antenna and then let go outside it would... Hmmm chaos perhaps.
Sep 21, 2007. 12:23 PMdentsinger says:
This sounds right up my alley.
Sep 3, 2007. 7:28 PMthemasterpyro says:
what the hell is this thing supposed to do??? 0_o
Sep 1, 2007. 2:03 PMmortaldoom780 says:
What IS this??
Mar 10, 2007. 2:34 PMjanesbigdream says:
After reading all of this, I still don't get what this is. I don't understand most of it... and after the list of things you'll need I feel really dumb. But I know these things aren't beyond me, I've just got to learn... and I am willing to learn. So, can you reference a book or an explaination.
Mar 9, 2007. 1:20 PMJsanges says:
Ok if you put a volt meter one way on a circut you get regular space time type reading.... you flip the terminals and you get a negative value ... have you found a way to pull in radiowaves from random space time , or just time for that matter>? like possible hearing a radio talk show about the condon report .. that would be pretty hot if this thing could tune in to negative space time and mabe atteunate it to past or present? crazy stuff... IM lovin it and if im compleetly wrong sorry it just jumped out at me
Dec 21, 2006. 9:55 PMgodbacon says:
can it be hooked up with an IR LED so I can scan.. like on a universal remote?
Oct 22, 2006. 12:47 AMdogsrcool2me says:
Does anyone know of a cheap pic programer to buy/make for this project?
1-40 of 63next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:VIRON
I'm a figment of my own imagination. ---- To Win the war on Terra Means to END the WORLD. How about a nice game of Chess? ---- I'm chilling, but forgive me for sometimes believing I invented everythi...
more »
