3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Propane Converted ATV
Hello all, this is going to be a somewhat simple instructables. So here is some background information on the build, it started when a few years back we had a Polaris 350 Trailboss, and the engine finally gave out after many years of enjoyment and after that we just let it sit unitl we finally remembered we had an old Honda 240cc cement mixer engine with a gear reduction already on it, so it sounded like the perfect fit for it. So without going much more into the background here is the build.
 Just to be clear I and the people involved in this took extra care while handling the propane, and we are not responsible for any damage caused to yourself or any property that you, (or your neighbors) may own. So please only attempt this if you know what your doing, and have sufficient common sense to know what you should and shouldn't do.
Also I am very sorry for the video quality thats all I could upload on to Instructables.
Here is a link to the youtube video it is of much better quality.  http://www.youtube.com/watch?v=RneAye-NetM
Here also is an older video of it with details. http://www.youtube.com/watch?v=xtaqvKldUrs
Step 1Getting Started
Getting Started
So first off your going to need a somewhat good mechanical background, and be familliar with som basic tools. Here is the main bulk of tools used,
1) A full Metric and Imperical wrench set, sockets also.
2) Some angle Iron. (If your doing a complete rebuild)
3) Screwdrivers, Allen wrenches(Hex keys)
4) A welder, (again only if doing a full rebuild)
5) A reciprocating saw, a drill, amd various other power tools. (again for a full rebuild)
6) Other basic tools you will know waht you need once you get into it.
As for the ATV, prefferable one that doesn't run, or it is old and you don' t care about it's safety, do not use it if it has a 2-stroke requiring pre mixed fuel, only use this conversion on 4-stroke or 2-stroke oil injected engines.
For the propane system we used a weed burner with an adjustable valve to regulate the gas.
14 comments
Apr 10, 2011. 11:41 PMbtan says:
I agree, very neat conversion. Thanks for sharing.
Would it be easier or more difficult to convert a 4 stroke fuel injected motor vs a carburated one? I have a fuel injected scooter that I'd like to try to convert.
Apr 16, 2011. 5:48 AMbtan says:
Scottrevoman333,
thanks, I'll give this a try. But I probably won't do this to my good scooter. I'll see if I can get an old junker similar to it and experiment on that one.
Mar 5, 2011. 12:43 PMmatt_and_nick says:
i actually have been thinking of making a moped thast runs on propane, due to such high gas prices
Mar 13, 2011. 8:38 AMmatt_and_nick says:
i was actually thinking of using a regulator from a small porpane camp stove, along with the small disposable bottles of propane you can get at wal-mart
Feb 27, 2011. 7:26 AMvistal says:
Would be a cool idea untill you burn out your piston .propane burns to hot to make this mod.
Feb 21, 2011. 8:43 PMaustin says:
how much propane does it use?
Feb 22, 2011. 4:10 AMrimar2000 says:
Excellent work. It reminds me an adaptation that my father did in the 60's, over a tractor that used an elusive fuel, it finally worked with a bottle of propane / butane.
I recently bought an electric generator of 220 V, 2.2 KW, which runs on gasoline, and will be likely adapted to run on natural gas (methane) as this is much cheaper. This instructable will be a very good guide!
Feb 21, 2011. 7:41 PMkylebo says:
This is really neat! I wish I had one so bad!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:scottrevoman333
