3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Propane Tank into Air Tank, The EASY way
I really like turning propane tanks into air tank, they last a long time as an air tank and the standard grill size holds enough air to fill 2 flat tires to 35 PSI on my car. The only problem is that I REALLY dislike removing the valve from the tank, sometimes I would even ruin the valve and not have a tank that is usable at all. On one city clean up day, I managed to get about 4 of these tanks, one was half full or propane yet and was still on the grill, I couldn't remove the regulator from the tank so I just cut the hose and went home with my new stash.
Once I remove the regulator at home, I inspected it a bit more and came up with a new way to get an air tank.
I know there are plenty of Instructables on this topic, but I have never seen it done this way before. There where tons of results that came up on "" Propane air tank" so I may have missed one.
Best of all, you only need one (1) adapter for an unlimited number of tanks.
Step 1Remove tank adapter
Remove tank adapter
Just remove the brass piece that screws into the tank from the regulator, this is easily done by clamping the regulator into a vise and using as crescent wrench to remove it, it is just standard threads which play a BIG role here.
Once it is off, you will either have a tiny, small, medium, or large hole in the end. If you have a medium to large hold, skip the next step.
In my case I had a Tiny hole, not much air will pass through that.
19 comments
Nov 1, 2011. 11:23 AMglorybe says:
This worries me a bit. Air tanks must handle moisture and normally have a drain valve to get rid of water. A propane tank may not face the same issues with moisture as propane probably has no water content. They also have no drain valve. I worry that these tanks may over time suffer loss of strength and explode. It could be very, very serious.
Perhaps an engineer that designs air tanks could chime in on this.
May 2, 2010. 8:51 PMheathbar64 says:
Brilliant!! Sometimes the simplest idea's are the best. the thought that immediately came to my mind is, Why not use the newer hands free grill connector?  Of course, the whole idea is using old obsolete tanks, so probably most wouldnt have that syle of valve.
May 2, 2010. 8:54 PMheathbar64 says:
 I meant tool free connector, not hands free.  Why can't I edit my comment once I post it?
Feb 21, 2010. 12:18 PMheavydeath says:
(removed by author or community request)
Feb 27, 2010. 5:49 AMheavydeath says:
Feb 27, 2010. 5:51 AMheavydeath says:
 the big valve has a tirevalve type thing and i found schrader valve keys but they are to short any help
Dec 29, 2009. 11:03 AMjaydenthorup says:
You could use this tank as an auxiliary tank to increase the air compressor capacity
Jul 3, 2009. 7:33 AMalaskanbychoice says:
Be careful of used tanks as they are being discarded for a reason, out of date for safety may be the biggest of them. Tanks can and do rust from the inside and around the welded areas. Where I work we sell bottles and propane and we have had safety bulletins about a tank blowing because of a weak weld. Luckily no one was killed. Test the tank by tapping it with a non-sparking hammer around the bottom and near the welds while listening to the difference in sound. You may also want to flood the tank with water to rid the tank of the smell before using it for an air tank. After which you may also want to add some alcohol to the tank to get rid of the water then let it air dry in the sun to remove the alcohol.
Jul 8, 2009. 5:27 PMRahdzhillaxxx says:
I use the hundred pounders for my house. How much pressure are they rated for? I really dont want to find out the hard way .
Jul 10, 2009. 2:35 AMstatic says:
According this http://www.propanecarbs.com/propane.html a propane tank fill with propane can see vapor pressures as high as 257psi. Use that as a guide at your own risk.
Jul 12, 2009. 5:25 AMRahdzhillaxxx says:
Thanx, I'm sure not to need that much pressure but its good to keep in mind
Jul 3, 2009. 1:13 PMDIY Dave says:
Where did you get the ball valve?
Jul 3, 2009. 1:38 PMDIY Dave says:
so it is a pumbing part?
Jul 3, 2009. 6:44 PMDIY Dave says:
Thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:scob89
