Step 17Finishing Steps
PWR
The LED that goes in the circle marked 'PWR' has a clear lens. For this LED, the SHORTER lead goes thru the circular hole (closer to the resistor), the LONGER lead goes through the square hole.
5.0
The LED that goes in the circle marked '5.0' has a green lens. For this LED, the LONGER lead goes thru the circular hole (closer to the resistor), the SHORTER lead goes through the square hole.
3.3
The LED that goes in the circle marked '3.3' has a green lens. For this LED, the LONGER lead goes thru the circular hole (closer to the resistor), the SHORTER lead goes through the square hole.
Also, add a 10k ohm resistor (Brown - Black - Orange) at R4
Next step is to test the power. Plug in your power adapter and flip the right angle switch down. The LED's should all light up, indicating that the Regulators are outputting power.
Add Comment
