First, flip on your soldering iron. Let it heat up while you check to make sure you have the following parts:
Parts list
- 3x 47uF Electrolytic Caps (make sure they're mico-mini so other modules will fit on top)
- 1x 4.7uF Tantalum Cap
- 1x 104 Ceramic Cap
- 1x 10k Ohm Resistor (Brown - Black - Orange)
- 1x 220 Ohm Resistor (Red - Red - Brown)
- 1x 470 Ohm Resistor (Yellow - Violet - Brown)
- 1x 1.1k Ohm Resistor (Brown - Brown - Red)
- 2x Green 3mm Green LED's
- 1x Red LED
- 2x Machine Pin Sockets
- 2x 4pin Sockets
- 2x 16pin Sockets
- 1x 4pin Right Angle Header
- 1x Right Angle Power Switch
- 1x Tactile Switch
- 1x 40pin DIP socket
- 1x 8pin DIP socket
- 1x 2mm Power Jack
- 1x 5Mhz Crystal (make sure it's half-height so other modules can fit on top)
- 1x 5V Voltage Regulator
- 1x 3.3V Voltage Regulator
- 1x Parallax Propeller
- 1x 32 kB i2c EEPROM
- 1x Propeller Platform PCB
