3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Propeller Powered Skateboard
Step 3Test It Out!
Test It Out!
This section documents the test phase of the project, which mainly includes standing on the board and seeing how fast I can go before I lose control. :-)
I started by doing some feasibility tests with a household fan, 12V battery, and an inverter on a skateboard. The results were disappointing, but not surprising. I needed more power!
A Model Airplane Using the Same OS 1.60FX Engine
Enter: The OS 1.60FX 3.7 HP model airplane engine. The most powerful engine in the world! Ummm.. not quite - but it packs quite a punch for an engine that weighs under 1kg. Much better than the heavy, low-power house-fan and battery setup! Even better than a 5 HP lawnmower engine for the weight. Additionally the engine is very high RPM (1,800-10,000), which allows us to use the small (model airplane) propellers. The main drawback is that the engine runs on Glow Fuel, which is made of methanol, nitromethane, and an oil, needs to be purchased at a hobby store and is much more expensive than gasoline. That said, I probably only used a couple bucks of fuel during the entire time I spent using the board and tuning the engine.
The first test ended shortly in propeller failure. The cage was just too close to the propeller, and with a slight vibration the propeller was caught in the mesh of the fan cage. Totally preventable problem, but I thought the tolerances were good when it really needed some more space. The next day, after reconstructing some of the engine mount which cracked in the propeller incident, it was time for test #2.
Success! The board cruised around the parking lot like an unstoppable freight train. Now this parking lot wasn't like most parking lots you might thing of. It was the parking lot to a long-neglected factory, and itself had been long-neglected. In other words: there were tons of rocks and grooves and cracks! So, what one might think of as quite mundane empty parking lot skating was actually quite exciting plowing over these rocks which would normally grind my skateboard to a halt when freeskating - in addition to the fact that there is no brakes and that the board wanted to take off even at low throttle.
10 comments
May 27, 2012. 2:58 AMjimmytvf says:
what about a chainsaw? you control the throttle with the servo as well, attach the chain to a sprocket and there you go! you get more power, is kinda lightweight and the gas is also cheaper lol
Mar 7, 2009. 11:08 PMKaos7125 says:
You should totally do this on a bike! I'd go for it in a heartbeat if it was on a bike
Oct 28, 2010. 3:30 PMyardkarter says:
I already did!
Apr 9, 2009. 6:01 PMMadrias357 says:
Working on that! Got me a plan for it.
Apr 20, 2009. 9:36 AMsebberdreng says:
Can i get the link to the plan?
May 12, 2009. 9:53 PMMadrias357 says:
Can you download a notebook? I'm sorry, my plans are to stay in notebooks. Anyway, I have limited supplies and was thinking of using the box-fan-on-power inverter to turn the wheel instead of trying to push 240 pounds of me and the bike around. Worst thing that could happen? I smoke up an old box-fan motor and have a smoker-unit for a mile or so. Or I get shocked. That's what electrical tape is for.
Aug 27, 2009. 11:51 AMbylerfamily says:
Ah,that remind me of someone I know who fastened a chainsaw motor to his bike...
Sep 17, 2009. 8:56 PMMadrias357 says:
Except I don't like gas. It's loud, smelly, and it explodes.
Dec 18, 2009. 3:26 PMZaphod Beeblebrox says:
but thats what makes gas so cool!!!
Feb 16, 2009. 1:27 AMDJ_JS9 says:
well if you need 10,000 rpm couldent you use a wd raptor hdd motor and a 12v battery??
Aug 16, 2009. 7:51 AMLetsExplodeSomething says:
Good idea but hdd motors only take 5v and if you were to use it with a fan blade it would probably work those things just don't have torque to be wheels or something encounters lots of resistance. i might try it
Jul 29, 2009. 5:44 AMJackp5 says:
build a car type one that uses like x3 of the materials but i dont think ur that loaded
Jul 28, 2009. 4:43 PMharvey639 says:
i would build one but i can't skateboard
May 19, 2009. 8:25 PMjonathonbryce says:
I WANT ONE!!!!!! Time to build it, it seems that it would be a cheaper way to work to.
Apr 25, 2009. 8:03 AMschweinhund227 says:
Pretty Kewl Idea !!!! but I would Switch the Remote for a Spring loaded Hand Throttle !!! if you fall ! the Board won't go Berserk on ya! If only I had one of those.... when I was a Kid !!! LOL Great Thinking !!! I am sure you Turned a lot of Heads Careening down the Streets.... LOL Way to go !!!
Feb 27, 2009. 11:09 AMmortemus says:
100% nerd power! Sweet! Maybe I'll adapt this my son's Big Wheel. He'd love it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:crazybuilders
Hey, my name is Ryan Bavetta and I live in Boston, MA. I work on a website: http://www.crazybuilders.com Follow me on twitter: @ryanbavetta
