3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Proper Soldering Iron cleaning & maintenance
Step 3Tinning the tip
Tinning the tip
After cleaning the iron, its a good idea to tin the tip. We will achieve this by allowing a thin coating of solder to cover the tip of our iron. This will protect the iron from oxidation as the solder serves as a sacrificial buffer zone against oxidation (it oxidizes rather than our tip oxidizing).
To tin your tip, use a tinning compound, available at RadioShack. If a tinning compound is unavailable, you can substitute this with regular electronics solder. I recomend a low temperature solder for this because you want the iron to cool fairly quickly, so you dont fry the solder onto your tip which would defeat the purpose of cleaning.
A properly tinned tip will look similar to the tip below. An instructable has been created by royalestel demonstrating the proper technique of tinning a iron tip. The instructable can be found here.
A properly maintained soldering iron will give you years of flawless service.
THE END
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:exponent
