3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Properduino - When an Engineer Gardens - Part 1 - Le Propergator Watering System
Step 10Drilling the holes in the side of the propergator!
Measure the size of the tubing that makes up your sprouts in mm. Add 2mm to that size. Go find that drill bit + drill. This is to make sure that the sprouts fit in the holes and you don't have to push a lot to get them in the propergator. If your propergator is heated, look out for
1. Mark out where you are going to put the hole with a sharpie
2. Make a dent like a centerpunch but with a screwdriver if you cant get access to one
3. Drill the hole through
Voila! Done. Now feed one of your sprouts through the hole and repeat for as many sprouts as you need for that propergator.
Repeat for as many propergators as necessary.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:grahamslawson
