3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Properduino - When an Engineer Gardens - Part 1 - Le Propergator Watering System
Step 5Connect relay power to wall!
Wire in the pump into the chocolate block you see in picture one. If your pump came with a plug on it, you will need a socket and some deep housing for it so you can store the relay and its gubbins.
After sealing it all up
Plug your contraption into the wall
Put your pump in some water!!!!
THEN
Send an R over serial
Now hopefully, your pump activated for 2 seconds and then cut off
Viola =]
You have a controllable chocolate block/power outlet if you used a socket and housing.
Thanks SparkFun! =]
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:grahamslawson
