3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Properduino - When an Engineer Gardens - Part 1 - Le Propergator Watering System
Step 6Making the backbone!
Le Backbone is used to carry the water pushed out from the pump and towards the general direction of the propergator/plant location. Le Backbone should fit onto the pump securely and then Le Backbone should run close to the propergator so the sprouts can connect to Le Backbone and then water your plants =]
Take the 12mm tubing *if your tubing isn't 12mm, pretend that it is =]*
Attach to your pump
Stick pump where you are putting the water
In other words, Put your pump in the bucket where you are gonna store the bucket and run Le Backbone to where your propergator are. If you can, put your bucket above the propergator to reduce the strain on your little pump.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:grahamslawson
