Protecing Paint From Freezing
Published
Introduction: Protecing Paint From Freezing
About: I am a teacher who enjoys environmentally responsible woodworking. Most evenings will find me in the shop working with my now 8 year old son Shay who is both my greatest helper and biggest fan.
Have an unheated shop or garage?  Want to keep your paint or welding rod warm and dry?  Use an old refrigerator!  You don't have to remove the compressor or the freon, just leave the unit as is and instal a incandescent light bulb of 40w or less hooked up to an old wall thermostat in the bottom.  When the temperature inside the unit drops below what you have set it to the light comes on.  Keep it set a 65-70 if you want your paint preheated and ready to use or set it to as low as it will go, normally 50, just to keep things fluid.  On the side-by-side I use one side is kept warmer than the other.  I keep the glue, caulking, putty and at a lower temp on one side and the latex warmer on the other.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    That's a great idea. Any chance of a picture of where the actual bulb is located?
    I have it at the very back on the bottom shelf so the heat can rise on up through everything.
